Jan-10-2019 06:19 AM
Jan-11-2019 03:53 AM
Jan-11-2019 02:27 AM
wildmanbaker wrote:
From the picture, that is the Ford frame that has failed, not an extension added by the Thor. I can't say for sure, but it looks like someone used a weight distributing hitch with this setup, that it was not designed for one. More than likely, the factory information packet also says to not use a weight distributing hitch either.
Jan-10-2019 07:58 PM
Jan-10-2019 05:35 PM
Jan-10-2019 05:04 PM
Jan-10-2019 04:52 PM
rgatijnet1 wrote:
I said that if the height difference was great, the force on the hitch could be greater, even if the tow bar WAS level. This is called leverage and that leverage will increase as the height difference increases. Hitches have a rated capacity when the load is level with the hitch receiver. If the drop hitch put the ball too low it could possibly have hit the ground at some point and put a lot of increased stress on the hitch/frame.
Jan-10-2019 04:48 PM
Jan-10-2019 04:45 PM
sundancer268 wrote:
Looks like an old crack with what I think I see is rust where the metal cracked. This probably has been growing for a while if it was a fresh break there would be a bright shine to the broken pieces.
Jan-10-2019 04:43 PM
Jan-10-2019 04:41 PM
Jan-10-2019 03:14 PM
Jan-10-2019 02:51 PM
judelaurenzo25g wrote:Did you catch that sentence? Have you ever removed an WDH stinger from the receiver, with the bars still attached? If you have, you know that their is considerable force usually up on the stinger. The bars tend to make a more fixed coupling between what is being towed and the TV. If the hitch is not a WDH, it can do just what you see in the photo. But then again, its just my experience.wildmanbaker wrote:
How can you tell a WDH was used? I don't see the hitch or the bars.
Jan-10-2019 02:39 PM
Jan-10-2019 01:33 PM
Jan-10-2019 11:56 AM
