Setting up
Engineman113
Brand new RV’er when i arrive at a site with a Class A MH
Do I
1 level the rig with the stabilizers then deploy the slide out
2 deploy the slide out then level the rig with the stabilizers
Thanks in anticipation of your answers and or discussion
27 REPLIES 27
SDcampowneroper
Try it both ways. slides are heavy, may tilt the rig one way or another. Do what is right for yours.
double check your leveling system with the best level ever, a frying pan with a little bit of water. Gravity wont lie, your leveler bubbles may.
olfarmer
I have done it both ways, it didn't seem to matter but I only have one slide. I would think the safest is to level then deploy the slide but as said above follow manufactures instructions.
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
wolfe10
Yes, it is not about arguments or which is right-- the right answer is what your coach engineers designed into YOUR coach.
Even if it is different than the coach someone else owns, it is correct for YOURS.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Mr_Mark1
Engineman113 wrote:
Don’t want disagreements I just watched a you tube on a new coach and they stated slide out first then level , just sounded not wrong but questionable
Like I said I’m a newdy and want to learn
Some manufacturers say level first then put the slides out, others say put the slides out then level. Check your manual.
Our Monaco Dynasty said put the slides out then level, our new coach says the same thing, put slides out then level.
Follow what your manufacturer suggests.
Good luck,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
rr2254545
Teacher's Pet wrote:
Depends on the manufacturer our '06 Tiffin Phaeton manual states to level 1st, I have heard some other brands direct to put out the slides then level.
Winnebago is level first - 08 Gasser and 12 DP
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee
492 Campgrounds,107K miles driven in our Winnebago motor homes and 2360 nights camping since we retired in July 2009, 41 National Parks
Engineman113
wolfe10
RognBon wrote:
Follow the coach manufacturers instructions.
CORRECT. What does YOUR owners manual say?
Brett Wolfe
Ex: 1997 Safari 35'
RognBon
Every time this subject comes up, it results in an argument over what's best. Follow the coach manufacturers instructions. With our Monaco, it's slides out first and then level.
RognBon
1997 Monaco Dynasty 40'
Cummins 8.3 325 HP
2008 Ford Edge Toad
Lwiddis
In my MH days I leveled, deployed slide and rechecked level.
Bruce_Brown
Moderator
Moderator
On ours it's level then slides out. It's that way on every MH I've ever know except the Holiday Rambler/Monaco twins.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
2oldman
It may depend on the behavior of your coach. If you level then deploy and that puts it out of level, it may be easier to deploy first.
Teacher_s_Pet
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
Mile_High
I always level first, then slides out myself, but I don't think it matters much unless you are pretty far off level.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
