sliding doors in back of motor coach
topher80
we have a 2008 HR Neptune (38') and we have two sliders in the back of the coach (in the bedroom. Unfortunately they are mirrored glass sliders and aside from having to look at myself when I go to bed, my wife and I would like to find an alternative to these sliders. They are heavy (because they are glass) an they are a pain because they don't stay latched.
Has anyone come up with a retrofit to change out the sliders.
Would love to hear about creative alternatives.
Thanks.
So after 33 years
I gave up golf...we'll see how this works
10 REPLIES 10
J-Rooster
Thanks.
Good Question! I'm going to be watching this post also! My door sliders in the rear (bedroom) are wood with a plastic band with snaps. And the plastic breaks a lot! I just put a pillow down when traveling and that's treating the symptom of the problem and not the cause!
Stuck_in_first
The mirrors add visual space to the room. Temporarily cover them with dark sheets and see if the room changes shape and if you like it..
tandkj
Mr.Mark wrote:
Have you tried new latches? We had to replace ours with heavier duty latches and they stay closed.
I was trying to think of a material that would be lighter and really anything substantial would be about the same weight. Maybe curtains would work?
MM.
Did the same, got new latches from Monaco and all is good.
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot Custom build
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
barnaclebill
I used 2 pieces of 1/2" CPVC water pipe cut to fit at the bottom of each track to get them from sliding incase the latch doesn't hold them. I hope this helps if you decide to keep them, Bill
2009 Monaco Camelot 42PDQ
425 Cummins
Chevy Equinox or Tracker
Blue Ox towing
Peralko
We have three pocket doors--two of them with mirrors. As long as we remember to close the latch, we have not had any problems with them. But the mechanisms are heavy-duty.
Peralko
USAF Retired
2000 Prevost Marathon H3-45
2006 Nissan Maxima
PapPappy
I was going to suggest getting a piece of wood, and place it inside, at the base of the inner door, so that it wouldn't slide, then another piece of wood on the floor to keep the outer door from moving. New latches would probably work as well.:)
I would probabl go with curtains (unless those doors are a standard size at HD or Lowes, where you can probably get a hollow foam door that would be much lighter than a mirror covered door.
Of course, you'll lose all that extra room you get from the mirrors:B
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau 🙂
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.😞
2000 Winnebago "Minnie" 31C, Ford V-10
Purchased April 2008:B FMCA# F407293
The Pets
Acampingwewillg
I have those sliders also and one doesn't like to stay shut so I just drilled a hole low on the door way into the frame and put a Pin in to hold it shut. I know, God forbid, I drilled a hole! :B
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund.
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie, Mollie, Elvis, Potter and Rosie Love You! (40+ years in all)
fulltime55
umm....Lowes??
AllegroD
Can you not remove the glass? Are they ugly without them? I personally like the two sliding doors around our bedroom.
Mr_Mark1
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
