Sep-21-2014 09:49 AM
Sep-23-2014 05:31 PM
Sep-23-2014 04:16 PM
Sep-23-2014 02:47 PM
Sep-23-2014 02:06 PM
Sep-23-2014 11:20 AM
Born To Travel wrote:Exactly what I have....High psi and high rate of recovery and at Lowes you get the vet's discount which more than pays for the tax.
I carry this one in one of the storage compartments... Always have my own source of air.. http://www.lowes.com/pd_57655-30449-0200382_4294795218__?productId=4686711&Ns=p_product_qty_sales_do...
Sep-22-2014 08:22 PM
DanaRuns wrote:
The sticker inside says all 8 tires (including tag axle) to be filled to 80 lbs. I have no idea how to weigh the load on each tire and calculate the optimum PSI.
Sep-22-2014 08:17 PM
Sep-22-2014 07:54 PM
Sep-22-2014 07:43 PM
Sep-22-2014 08:53 AM
Sep-21-2014 07:32 PM
Sep-21-2014 04:12 PM
Sep-21-2014 03:16 PM
Sep-21-2014 03:02 PM
DSDP Don wrote:
Dana.....If you feel comfortable filling/checking your own tires, this is a great compressor that many of us use. It's available at Sears and has plenty of pressure to fill your tires.
The air chuck (filler) locks onto your valve stem so you don't have to hold it. It even has a gauge built in that gets you pretty close to your target pressure. You can check with a tire gauge when done.
It runs on 110 volts so you can even use it when camping, just start your generator. It has other attachments for filling things like balls and toys. Lastly, it's compact and fairly light weight (20 lbs) I stick it in an old pillow case and store it in my bay.
