Technique for removing graphics?
AstroRig57
Does anyone have a "best method" for removing graphics from a Class-A motor home? Heat gun? Solvents? What works without damaging the wall structure and finish?
I'm looking to remove most of the graphics from our Winnebago Sightseer to be replaced with custom astronomy related graphics, images of galaxies, nebula, etc.
We did the same on our previous Class-C but, because it had a large rear window, we just had a big graphic made out of window perf.
Thanks
2005 Winnebago Sightseer WFD30B "rigged for night" with red LED lighting for night adapted vision.
Do you remember when the sky was dark, and the stars were bright?
The International Dark-Sky Association
American by birth...Scottish by the Grace Of God.
10 REPLIES 10
Busskipper
Thanks
Heat gun - not too hot and I have had great luck with old credit cards, cut to give you a sharp edge - just be careful not to use too much heat take your time and they will pull off slowly.
BOL,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
GX470-FMCA - Travel less now - But still love to be on the Road
States traveled in this Coach
sjholt
http://crystaltek.us.com/crystaltek-vinyl-off.htm
This worked for me with 20 year baked on graphics.
it goes slow with plastic razors.
One Qt will cover a lot.
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
AstroRig57
RLS7201 wrote:
When I restriped my 95 Bounder I used PPG's DuraPrep Prep502. Apply stripper on the stripe/decal, go sit in the shade for 15 minutes with beverage of choice. Return with plastic putty knife and remove the vinyl. Reapply stripper and finish removing glue. I tried heat and 3M eraser. The PPG stripper was the least labor intensive. A gallon of the PPG stripper will also strip $75 from you wallet.
Richard
Winter's going to be over soon. This is still an ongoing project. My problem has been in finding anyone willing to sell me the PPG DuraPrep Prep502. I haven't found a source online and, when I ask, local paint shops look at me like I've I've got three eyeballs.
Does anyone know of a source for DuraPrep Prep502 willing to work with do it your selfers?
mike_brez
Richard
At $75.00 that would be one of the cheapest strippers that I purchased :E
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
RLS7201
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Dick_B
For previous posts on this subject search this Forum for `graphics' then search the results for `remove' and read on.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
scbwr
WD40 was really good at removing adhesive residue when I removed graphics from our Sunline travel trailer. I used a hair dryer (heat gun would work) and plastic scrapers.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
Dale_Traveling
I striped the sun stroked black graphic on one side with a heat gun and the other side using a 3M Stripe Off Wheel. Heat gun was a bit of work but didn't cost anything since I already had the gun. The wheel was really quick and easy but cost me $27 a wheel and I needed two. Both left a bit of residue what wiped off with mineral spirits. The area under the graphic was almost pure white and was slightly noticable in bright sun light. Just something to consider.
2006 Hurricane 31D built on a 2006 Ford F53
10forty2
I did a small set of graphics on the rear of my coach to replace with a custom graphic that I had made. It was a royal pain, but I finally did it without damaging the structure or finish. Best method was a hair dryer and a lot of patience. Solvents made the color on the graphics run and then there was the whole problem of the color staining the surrounding surface of the coach. I did use one of those plastic scrapers to help get the stickers off once they were heated. You will be left with some of the glue and there really isn't any other way to get that off except for a solvent of some sort. I used Goo Gone and lots of elbow grease.
Good luck!
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
Bumpyroad
power washer?????
bumpy
