Tire Pressure
bullydogs1
My Pressure Pro system is getting a bit old and I am tired of having to replace sensors....What is a good system..there is one called Tire Minder on sale that is priced reasonably but it is stating for brass/steel rims...I have the Spartan chassis...is there a difference with the sensors...I have had no issues with fit for the current pressure pro sensors but their system is over $200 more ...thanks in advance for a bit of guidance here.
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
15 REPLIES 15
bluwtrman
Regarding air stem material - is anyone putting the sensors on the rubber stems that come on the wheels? I talked to the "guru" at Camping World and he says replacing the stems isn't necessary as the sensors are only 1/2oz ea. I'd like to save the $ and time of replacing the stems but not if that buys me a bigger problem later...
Mile_High
Dutch_12078 wrote:
Mile High wrote:
Tireminder makes two sensors - one for brass and steel stems and one for aluminum like the newer cars have with built in TPMS. It has to do with electrolysis and corrosion. The standard sensors are brass threads and will corrode on an aluminum stem, so they make an all plastic sensor for aluminum stems.
Brass threaded sensors work fine on aluminum stems if you coat the stem with dielectric grease or anti-seize first.
Or you can order the plastic ones that are the same price I believe. On my Jeep I use deflaters, standard caps and the tireminders so I really don't want to grease them up, but in reality I use the brass on my aluminum. They don't stay on there long enough to worry about.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
Mile_High
We have the Tireminder TM66 and I gave one to my daughter. So far so good. I've had 1 bad sensor out of 12 (8 MH + 4 toad), and another that I broke the battery compartment. They send you batteries every year and they need them every year.
Lwiddis
Read these replies carefully. Will reconsider.
Dutch_12078
Lwiddis wrote:
No, Tom, it won't. I'm sure you understood my point that I don't believe these expensive and fragile systems are necessary.
Our TST TPMS has alerted us to a failed wheel bearing and a stuck brake caliper on our toad and a slow leak from wood screw in a rear coach tire, all occurring while under way. Would your morning pressure check have caught those incidents? There's good reason they've been mandated on all light (under 10K pounds) road vehicles for the past 10 years by the TREAD Act.
Dutch
Ivylog
I recently replaced all 10 of my PP sensors (after 10 years) for $250 direct from PP. I do loosen the sensors when not going to use for a couple months.
Upgraded with a 08 HR Navigator 45’...
Tom_Barb
First time one saves your azz you'll believe.
Odessa Texas, 105 degrees, we get a warning of an over temp on a front tire. we slowed and ran until we found a rest area. took a nap until the tire cooled off, had we not gotten a warning we may have caused a blow out and all that goes with it.
My most concern is heat.. that is why most tires fail, that one time I feel paid for my set of TST monitoring system.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
Second_Chance
We have the TireMinder A1A for all 10 tires on the ground. The sensors come in two different materials based on the valve stem material - not the wheel material. This is to prevent electric corrosion from dissimilar metals. We've been very happy with the system and it saved us a lot of damage from a road hazard incident.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Lwiddis
ncrowley
I have been using Tire Minder for 5 years and I really like the system. They also have excellent customer service. Tireminder makes different sensors so it is best to call them and make sure you get the right ones for your RV and your toad.
Nancy
Newmar Northern Star
AFChap
Tire Minder & Tire Traker used to be the same system ...don't know if they still are. I have been very happy with my Tire Traker system. They now have a new monitor, and a life-time guarantee!!
Paul ... was Fulltimin... now HalfTimin!
KE5LXU, SMART, WIT, FMCA, Good Sam, Escapees
'03 Winnebago Ultimate Advantage 40E / '17 Jeep GC Limited
Tom_Barb
Lwiddis wrote:
My system is to check each tire, TT and TV, each morning before sun hits. Cost? $12 pressure gauge. And I'm a pro! That's my take on TP gagetts.
Will your tire gauge tell you when you have just had road hazard damage and a tire is going flat?
Lwiddis
