Sep-15-2014 11:21 AM
Sep-17-2014 11:43 AM
Sep-17-2014 06:06 AM
Gjac wrote:hipower wrote:I wish I did not have experience with leaking seals but the main seal on my eng was leaking when I bought the MH it sat for a while without use. Once I started putting miles on it the leak went a way. I notice a small leak even after sitting over a 5 mo. period of non use.
Those who mention seals drying out and leaking, do you have any personal experience with that actually happening in the last 25 years or so?
Seals were made of leather, cork and oil impregnated ropey materials years ago and did dry out and sometimes leak. Those materials have been gone for years and the newer materials don't seem to experience the drying effect and only leak when improper installation or damage is a factor in my experience.
Sep-16-2014 01:00 PM
Sep-16-2014 12:49 PM
vjstangelo wrote:It should. I don't think Ford ever mated the 5R110W transmission to the older engine design. Might be best if you could call the dealer and see if they will give you the VIN so you can research this a bit deeper. The chassis label model year of 2005 has me scratching my head.Dale.Traveling wrote:
Ford updated the chassis with the 2006 model year but a 2006 coach you could have a 2005 chassis under it. The noticeable change will be the 'Tow/Haul' selector on the end of the gear shift and the corresponding dash indicator. The older transmission was 'OD On/Off'.
Exactly. It is a chasis model year 2005 per the mfg label. The transmission has the tow haul which means to me it is equipped with the torkshift transmission. Does that mean that it has the higher hp V10?
My 2005 Excursion has the venerable 4R100 with the OD light on the stalk. The V10 in the Ex is the 310 hp version.
Sep-16-2014 09:39 AM
Sep-16-2014 09:27 AM
Sep-16-2014 07:58 AM
Sep-16-2014 05:30 AM
Sep-16-2014 05:21 AM
Sep-16-2014 05:01 AM
Sep-15-2014 08:22 PM
Sep-15-2014 06:29 PM
Sep-15-2014 05:52 PM
Sep-15-2014 05:11 PM
