using shark bites on pluming
ocean_bound
has any one used shark bites ( push on fittings)on pipes in a rv and how are they holding up.
Allen&carrie 2006 georgetown XL359 37ft
23 REPLIES 23
Teacher_s_Pet
I have used something that works similar on plumbing repairs sold by Menards. Except no special tools are required to remove the fitting, just press "in" on the white nylon collars, that snap "out" when the tubing is pushed into the fitting. The first ones I used were transitions from PVC to PEX on laundry service connection repairs at one of our duplexes. I have used several times since without any problems to date.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
gbopp
I've had SharkBites and Pex in my S&B for 10 years. I used them on the hot water heating system and the fresh water system.
Absolutely no problems.
And, I've had a couple in our Southwind for a couple years. Again, no problems.
I've never tried the similar brands.
fitznj
I love Shark-Bites and PEX: I've used them for several years now with NO problems. I like the fact that you can disconnect them if you've made a mistake and are planning the layout before final setup.
They may be a bit expensive but how many do you really need?
Gerry
Gerry
thomasgunnar
I have used something similar. Just another brand I guess. I was somewhat unsure of how well they would work. Needless to say they work great. I have used them in home plumbing as well.
Chris
2003 F350 CC,4x4,6.0,Zoodad, 3 Pod Pillar Gauges, Sinister Coolant Filter, Scangauge II, Blue Spring Kit
2006 Jayco Eagle 301RLS 33'
Dick_A
Shark bite connectors but rather expensive and one should use their tool to camphor the pipe end before inserting the pipe into the fitting. Also, as mentioned you will need a removal to remove the connector.
Another good connector is called flair -It and offers a good connector product line at reasonable prices. These connectors require no special tools to install or remove. you can find these connectors at most RV parts departments.
There are other systems but are usually used in high production work
2009 Tiffin 43QBP Allegro Bus
RoadMaster Sterling Tow Bar
US Gear UTB
Ford Explorer Sport Toad
WA7MXP
"Pisqually" the attack kitty :B
Executive45
Re-plumbed my water pump last year as I didn't like where it was located. Used shark bites. No leaks, no problems. Easy to use..Lowes also has a similar item. They call them Gorilla snacks or something like that...:).Dennis
Old-Biscuit
Better than sliced bread.........
Just make sure you cut the PEX straight across and no burrs or gouges
And get the 'removal tool'------'C' shaped device that will allow you to remove SharkBites.
1/2" PEX is used in RVs.
Alternative...
Flair-IT Fittings 2 yr. warranty
LINK
owenssailor
Used them in our old trailer - worked great.
Just installed a dishwasher with my son-in-law today - used sharkbites - worked great.
2011 Jayco 28U
2012 Chev Silverado Crew Cab 5.3 6 spd 3.42 (sold)
2017 Chev Silverado Crew Cab 5.3 8 spd 3.42
Equal-i-Zer 1400/14000
RotoChocks
dons2346
Great stuff, they don't leak
