Vail Pass
Colo_Native
I went east over Vail Pass and my 34' MH with toad went up the hill at 28 mph it is the first time I have done this is this what I should expect from my 2008 V10 Gasser?
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
13 REPLIES 13
Mr_Mark1
Colo Native wrote:
Blaster Man wrote:
The OP has a gasser and a number of posts are from guys with diesels...that's an apples to orange comparison. Also, the altitude gain will not affect the turbo diesels like it will a non turbo gasser.
I have to believe that some did not read gasser but I get the idea nothing goes fast up Vail pass!
Yes, I think that was the point, we knew he said gasser but just wanted to point out that nobody is going to fly up that pass.
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
Colo_Native
Retired DFD
Blaster_Man
2014 American Eagle
RLS7201
My ol 95 Bounder w/460 and toad, runs up vail pass at 35 MPH with no problem. It would go faster but I limit my climbing to 3,200 RPM. Maybe the Banks Power Pack exhaust system has something to do with it? GRIN
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
time2roll
I would call normal on that. My 5.4 pulling 7k did about the same.
As long as you are running cool just enjoy the ride.
hanzfranz60
Yes! I lived in that area for 25 years and drove cars, buses, RV's, and trucks. Gas RV's seem to do 25-30 mph. Heading east from Vail, it's a seven percent grade for miles before you reach the top at over 10,000 feet above sea level. High altitude definitely plays a part here!
427435
Were you running with foot on the floor in 1st at 4000+ rpm??
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
Mr_Mark1
Vail pass is a very steep L O N G grade and I think we went up back in May at about 33-35 mph. Our 2008 Dynasty weighs just over 40,000 lbs. pulling a 3,500 lb. toad. Our engine and transmission temp went up but was not bad, maybe up about 5-8 degrees each.
MM.
Mr.Mark
Ivylog
Yes.
Upgraded with a 08 HR Navigator 45โ€™...
msmith1199
Remember not only is it steep, it's a very high elevation too. Combination of the two are hard on any internal combustion engine. Did you notice that even most of the cars were down around 45 or so?
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
camperguy99
Sounds about right to me? I traded my F350 V10 for the 6.7L diesel. Added 10-15 mph to the Vail Pass speed. Pulling a 30' 5th wheel with a Ford Explorer behind the 5th. V10 speed was similar to what the OP quoted.
Dog_Trainer
Having been over Vail pass and the eisenhower tunnel a few times you could get down to about 25 MPH. I pull it at about 35 MPH and I am pushing the heat up to over 200 by the time I get up it. @ WOT I would overheat so I try to get it in the sweet spot of around 1850 RPM. just sit back and enjoy the ride.
2016 Newmar Baystar 3401
2011 HHR Toad
Daktari & Lydia Cavalier King Charles , Annie get your guns, our English setter (fur Bearing Children)
hanko
I would think much better than that.
2014 Tiffin Open Road 36LA,Banks Power pack,sumo springs, 5 star tune, magnum invertor
2013 Ford Focus Toad
Haigh Superstar
