water heater
9ers
I was staying in PA this weekend could not get hot water heater to light.I have a atwood unit automatic lighting from switch inside coach. I cleaned all connections and still nothing. After these tried to ignite manually turned on switch and there was no propane coming from the line. I was wondering if propane regulator could be going all other appliances work stove,furnace. If anyone has any ideas I would like to hear.
Thanks
Thanks John
5 REPLIES 5
Johno97007
I had the same problem with our new to us Horizon. Then I found out that a water heater filled with hot water won't light when you switch it from 110 to gas. I turned off the 110, drained some hot water into the sink and hit the switch...worked perfectly. I used the gas heated hot water to wash the egg off my face.
John & Sherryl
Retired and Loving it!
2004 Itasca Horizon 40 AD
Cummins 350
2006 Chevy Trailblazer (The Anchor)
Old-Biscuit
What model do you have?
12V power has to go to switch then to/thru both set of t-stats and then to module before 12V power is sent to gas valve and spark electrode.
Bad/loose grounds in outside compartment
Faulty thermal cut out (if you have one)
Faulty t-stat(s)
Bad module
Dirty connectors on module
BrianinMichigan
I had one of the two solenoids on my gas valve go bad. The coil opened up. It sounded like the valve was opening up but only one side. I measured the thickness of the wire and rewound the coil. That was about 5 years ago anf it's still working good.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
enblethen
Check continuity on the ECO and thermostat. They both should have continuity when cold.
Under the tubing adjacent to the ECO/thermostat is a thermal fuse. Check it for continuity.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
workhardplayha1
You are in luck......your water is already hot......you don't need to heat it.
I had trouble with my WATER HEATER. My unit has a spring loaded connector that twist into place. The ground came loose.
