Tank level gauges misreading
mustex
Hi,
I have level gauges on my RV (like everyone I assume) but they are currently misreading the correct levels.
Does anyone know how to clean the sensors? I have tried flushing my waste tanks.
How hard is it to replace the sensors?
19 REPLIES 19
lostmarbles
BarbaraOK wrote:
lostmarbles wrote:
I thought we killed this subject several years ago...
Naw - the number of 'remedies' keeps expanding and new people keep worrying about tank levels instead of just learning by using what their tanks will hold.
Barb
Oh yeah. I remember now.
Gadget_Guy1
BobGed wrote:
I installed the following system in my coach four years ago and it has been working flawlessly ever since.
SeeLevel Tank Monitoring System
X2, one of the best mods I have done. Works 100% of the time but then it was designed and is manufactured in Alberta, Canada
lhatton
All of my tanks are visible somewhere.
After calibrating my fresh water tank (knowing how much my supply hose would provide in a minute) and marking the side of said tank with a sharpie, I was able to calibrate the gray in a similar manner (5 gallon loss in the fresh = 5 gal in gray with shower running.)
I did re label the electronic gauge to show the correct quantities (mine work most of the time), but if in doubt, a quick check of the appropriate compartment is easy.
The black tank, well it's easy. Just a long flush with a flashlight in hand will give you a good clue about remaining capacity. It's never a problem as Fleetwood went 50/50 on the gray/black on mine. Wish it was 70/30.
1994 Pace Arrow SOLD IT!
2000 Discovery
2002 Wrangler
The one I have left may still be too many!
BobGed
2017 Tiffin Phaeton 40QBH
2014 Jeep Cherokee Limited
Turbo_Diesel_Du
Calgon and let it stand for a few hours filled with water. Flush thoroughly. Repeat when it goes south again.
charles weidman
BarbaraOK
Barb
Barb & Dave O'Keeffe - full-timing since 2006
Figment II
(2002 Alpine 36 MDDS) ๐Ÿ™‚
2018 Ford C-Max HYBRID
[purple]FMCA - F337834, SKP #90761[/purple]
Our Blog
lostmarbles
wallynm
Fill it to half full of water and black water. 3 table spoons of ridix and 5 to 10 pounds of ice cubes and then drive 50 to 75 miles.
mustex wrote:
Hi,
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
fla-gypsy
There are millions of RV's that have level indicators that don't work correctly. It is a waste of time to pursue IMO.
notruffinit
SDcampowneroperator wrote:
Common sense on water usage will prevail over technology. don't waste your time & ' $ ' 'cleaning' the sensors. Even if it works for that time, it will not work for long.
Know your tank capacities, educate your family on them, and the indications ( burping ) of a near full tank.
x2. I just gave up on the sensors. I know how much and how many days I can go. I know because when I parked in a boondock like situation, I actually "measured" how much was in my tanks after several days using a 5 gallon bucket. After a couple of weeks I know how much water we use and know that the DW and I can go 4 to 5 days without worrying about the gray tank and 7 on the waste tank.
'11 Ram 3500 Cummins
'12 Cameo 34SB3
muelldawg
Good "Common Sense" Advise, SDcampowner
Richard & Marilyn
2010 Jayco, Jay Feather, Sport 16.5 feet
2010 Ford F150, V8, 5.4 liter
SDcampowneroper
Janss
J-Rooster....I have used that product, but not exactly in the way you describe. I'm going to try that when I get home from my current trip. I've just added it with a bunch of water (maybe 1/3 tank) and let it slosh around while I drive to next campsite.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
Janss
I've tried several of the suggestions on these forums and still, sometimes my sensors work and most of the time they don't.
