What CAT engine do I have?
Bucky1320
I'm pretty sharp with the gasser stuff, but my father in law is a truck driver, and has asked what CAT my 99' Harney Renegade 275 hp has. I would prefer to not stand there with my deer in the headlights look if I could avoid it. What can I tell him?
1999 Harney Renegade
Mostly used for overnights at the drag strip.
33 REPLIES 33
Bucky1320
RayChez wrote:
It probably has the 3126-B
That was my conclusion. The cruise worked for a short while this weekend and then it didn't forever more. It's strange: Sometimes the speedometer is within 1 mph of what the GPS says, and sometimes it is 9 mph off....slow
RayChez
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Bucky1320
Update: Had the codes cleared, and the cruise takes off working fine. Strange. We will see how long this lasts.
Bucky1320
fcooper wrote:
Bucky1320 wrote:
....text deleted....
I'm trying to figure out what I have so I can start diagnosing an intermitant cruise control. ....text deleted
What chassis does your coach have?
If Freightliner, the brake light switches (2 of them) are mounted on the brake tredle, and are accessed from under the coach. A failing switch (or corrosion on the wire terminals) is a common cause for cruise control failure.
Fred
It's a Magnum. I wonder how you test the switches? I can access mine pretty easily.
fcooper
Fred
Fred & Vicki
St. Augustine, Florida
Bucky1320
I did realize that the high pitched beep I THOUGHT I was hearing and the intermitant additional beep when we would hit bumps or get off level a bit was coming from a REMCO control box on the dash. I pulled the fuse out of that when we got home and hope that clears up the noise. I wonder if that would have anything to do with the cruise. Not sure exactly what the box was for.
2oldman
mdanielson55 wrote:
some coaches wont let the cruise work if the headlites are on bright
That sounds hard to believe.
John___Angela
wolfe10 wrote:
John & Angela wrote:
There is a 2001 Georgie Boy cruise master with a Cat 3126. From what I can see it is not the E variant. I have been under the impression it was a 300 HP version but honestly can't find that indicated anywhere. I am assuming it is least the B variation at 800 lbs torque.
Call the Caterpillar RV Hotline with the engine serial number (on the valve cover). They can not only look up the specs, but tell you exactly what HP and torque it did on the dyno before leaving the Caterpillar factory.
877 777-3126
Thanks Wolfe. I'll pop the bed up tomorrow and take a peak. Its one of the units on the lot. Kinda of a nice to know not need to know thing as I think there is only a 60 pound difference in the torque rating. I like to play with all the buttons and knobs on the units when they come in and have the various specs figured out. Always find interesting goodies. Took me awhile to figure out that the coffee holders at the drivers and passengers positions were heated. 🙂 Go figure. 🙂
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
wolfe10
877 777-3126
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
John___Angela
There is a 2001 Georgie Boy cruise master with a Cat 3126 on the lot. From what I can see it is not the E variant. I have been under the impression it was a 300 HP version but honestly can't find that indicated anywhere. I am assuming it is least the B variation at 800 lbs torque.
khahuna
My 2000 Harney Riata has the CAT 3126B, 300 HP.
Dave & Jan Bussard
2016 Jayco Designer 5th Wheel 39RE
2016 Ford F350 CC 4x4 DRW w/8 foot box
Chloe Anne - passed 10/05/2016
Izzy - gone 08/12/2013 but not forgotten
Bucky1320
More things to check anyhow. Thank you guys. I will let you know what I find.
FIRE_UP
mdanielson55 wrote:
YOU SAID AN INTERMITTENT CRUISE problem. some coaches wont let the cruise work if the headlites are on bright. also if you have a jake or engine break on your cruise will not engage,
Wow, that's a new one on me. Never heard of cruise being canceled due to "High beams" being on. And, Our exhaust brake switch is ALWAYS ON, and our cruise works just fine. While maybe some chassis manufacturers MAY curtail certain operations of engine/cruise/E-brake/Jake Brake/ etc., not all do.
Scott
Scott and Karla
SDFD RETIRED
2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
wolfe10
Don't know about headlights canceling cruise, but on many many coaches, exhaust/engine brake switch on WILL keep cruise from engaging.
Just as will stepping on the brake pedal!
Brett Wolfe
Ex: 1997 Safari 35'
