Whats the best Class C RV
Kallen8
I'm just starting my hunt for an RV. I've decided on a Class C MH and was wondering if there was a consensus on which model is the best overall?
50 REPLIES 50
Kallen8
Thank you so much for all the advice! You were right...there were as many opinions as I could ever need. I decided on a 2012 Holiday Rambler Alumilite 31WPS. It has everything I need and the price was in my budget (which was a big deal).
It has the Ford engine many of you described as desirable and will fit my large family without feeling too squished. Tons of storage! It does have one slide out...I didn't care either way. I'm not smart with mechanical things, so my plan is to have it serviced and the roof inspected every 6 months at the dealership. Crossing my fingers that I got a good one!
DiploStrat
U-Joint is another van converter. http://www.ujointoffroad.com
DiploStrat
1990 Mercedes Benz 917/XPCamper
Website: https://diplostrat.net/
ron_dittmer
Dakzuki wrote:
ron.dittmer wrote:
pnichols wrote:
Ron,
Since PC's 4X4 option (like most light truck 4X4 conversions) employs a solid front axle suspension, I wonder if Ford's notorious front end problems resulting from their "Twin I-Beam" suspension's loading and alignment are once and for all eliminated??
That is an interesting question of which I have no idea if the Quigley 4x4 conversion benefits in that way.
We have a Quigley converted E350 where I work with lots of miles on it. No issues with it whatsoever regarding the front end that I know of. I also knwo a guy with a Sportsmobile 4x4 E series. He has lots of miles and just had the front suspension gone through as it was getting sloppy. Some of the parts are spendy and definitely not something you get at the auto parts store as they are particular to the conversion.
Good to know. Thanks for sharing that Dakzuki!
Dakzuki
ron.dittmer wrote:
pnichols wrote:
Ron,
2011 Itasca Navion 24J
2000 Chev Tracker Toad
DiploStrat
mlts22 wrote:
If the ride isn't boneshaking, I've liked the idea of a 4WD motorhome. It wouldn't be hitting the Moab hot tubs in Hell's Revenge, but the higher ground clearance coupled with the ability to head further into the backwoods can come into handy.
Plus, flipping on 4WD sure beats having to find someone with a heavy duty wench to unstick your vehicle.
Tiger Adventure Vehicles, based on one ton or larger pickups, are definitely not bone shakers! Tiger
DiploStrat
regis101
Thanks, Ron. You're the best.
Peace. ~RL
RobertRyan
The Isuzu based Earth Cruiser(Host Camper assembled) has an All Terrain Motorhomes developed suspension that rides and handles like an SUV.
mlts22
ron_dittmer
pnichols wrote:
Ron,
pnichols
Ron,
2005 E450 Itasca 24V Class C
ron_dittmer
I did not read through all the replies so maybe much of this is redundant.
I put this together a while ago for people asking the original posting question.
New or used, when shopping for any conventional class-C, the most important consideration is how it is constructed. What construction methods are used to be most affordable, and what methods cost more but are built to hold up much better to the elements and the punishment of a constant earthquake when being driven.
Some motor home manufactures offer different levels of quality through their various model lines. Instead of providing a list of brands to consider, it is best to identify what "Better" is.
When shopping for a motor home, don't get distracted with what I call "Eye Candy" and/or "Square Footage". You want to pay close attention to how the house is constructed. Water penetration is the number one killer of motor homes, rotting them away long before anything is worn out. Once water gets in, it is like termites. By the time you realize there is a problem, a lot of damage has already occurred. Mold can also grow inside the walls which then you have a health hazard. My advise focuses on identifying a Reliably Well Sealed motor home.
#1 BEST (Very Expensive, Can Be 1.75 to 2 times the cost of Second Best)
NO structural seam work. The brand Coach House is a fine example. It is seamless, made from a mold. The only places where water can leak is cutouts for windows, entry door, roof-top vents & a/c unit, storage compartments & maintenance access, all of which are in areas of very low stress. Because they have a seamless shell, these motor homes are limited in size.
#2 SECOND BEST
Common, Affordable, & comes in Many Sizes so this is my main focus
I own an example of this type. My Rig Here manufactured by Phoenix USA.
Made in sections, but assembled in a way that greatly reduces the threat of water. Here are the good things you want to look for.
a) Structural Seams Away From Corners
When a motor home is driven, the house bounces, resonates, shakes, and leans, many thousands of times, representing a series of extended continuous earthquakes. Corner seams see greater stresses than seams located elsewhere. Corner seams are more easily split, especially when the caulk gets brittle with age & exposure to the sun. One extremely bad bump in the road can instantly breach a corner seam. Seams hold up much better when they are brought in from the corners in lower stressed areas.
b) A Seamless Over-The-Van Front Cap
A huge bed above the vanโ€™s roof is the most vulnerable area of a motor home. No matter how well they are made, that long frontal over-hang resonates when the RV is driven. It is common for seams to split there, most troublesome with age & exposure to the elements. The small front aerodynamic cap of a B+ design eliminates the overhang which eliminates most of the resonation, along with most seam work.
There are a few conventional โ€œCโ€ Designs (big over-van bed) where that area is seamless. If you absolutely must have that huge bed, then look for a seamless bucket-like design. Born Free offers a seamless bucket design as seen in This Model. Winnebago's View Here is another fine example. Some manufactures as of late offer a partial bucket design with fewer seams located in less-stressed areas. The Nexus Phantom applies a partial bucket concept. If you plan to accommodate more than 2 people, that extra bed would be extremely important.
c) A Crowned Roof
Rain and snow melt runs off a crowned roof. A flat roof will sag over time, then water puddles around heavy roof-top items like the a/c unit. Water eventually finds it's way inside after gaskets & caulk have degraded from age, sun, and change in seasons.
d) Rolled-Over-The-Edge seamless Fiberglass Roof Sheathing
A single sheet of fiberglass that rolls over the right & left sides of the roof, down the wall a few inches. The fiberglass sheathing holds up better than roofs made of sheet rubber or thin plastic called TPO, which require more attention to keep your RV well protected.
e) A 5 Sided Rear Wall Cap
This 5 sided back wall moves the seams around to the sides to areas of much less stress.
Potentially Troublesome Construction
Entry level motor homes are made with seams in corners and finished off with trim, including the massive cab-over bed. Their roof is flat and finished with rubber or TPO. They are most affordable, and come in all sizes. HERE is one such example. If considering this construction type, keep in-mind they require more regular care with bi-annual inspections. Plan to use a caulking gun now and then. When buying a used one, consider that you really don't know how well the previous owner maintained it. Buying new or used, that construction method will be counting on you to be a good non-neglectful owner.
There are also rare exception like the Lazy Daze which has seam work in the corners, but the substructure and sealing method is of the highest quality that it holds up like a seamless body. It's excellent sectional construction methods are not commonly found in other brands. I am no expert on this, but I'd give it a #1.5 Almost Like Best
About The Chassis
The most popular is the Ford E-Series with the V10 engine. The Sprinter diesel is a popular alternative to the E350 in the smaller sizes. The GM chassis is not popular, but is a very good choice for the right application. Any of those three brands since 1998 are real good, new or used. If you plan to tow a car or heavy trailer, be aware that the Sprinter is the least powered chassis. People who tow with a Sprinter, take it slower.
If considering a recent โ€œsmallโ€ class B+/C motor home, here is a comparison between the two main contenders, the Sprinter with the V6 diesel engine and the Ford E350 with the V10 gasoline engine.
Advantages Of The Sprinter With Diesel Engine
- Offers a 35% improvement in fuel economy over the Ford-V10, when both are loaded and driven identically.
- More ergonomic driver compartment with more leg room.
- Comfort continues with a car-like feel & quiet ride.
- A grander view out the windshield
- Made by Mercedes which people are attracted to.
Advantages Of The Ford E350 with V10 Engine
- Given identical motor homes both brand and model, the Ford is around $13,000 MSRP cheaper
- The Ford V10 engine has 50% more horse power and torque
- The Ford E350 chassis handles 1430 pounds more weight.
- The E350 is able to tow a heavier load.
- The E350 rear axle is significantly wider which translates to better stability.
- In most places traveled, gasoline costs less than diesel fuel
- The Sprinter diesel has limited mechanical service shops around North America
- The Sprinter diesel is typically outfitted with a propane generator. Propane is a critical fuel for RV operations, and generally needs to be rationed when dry camping.
- This Next Point Is Debatable But Still Worth Noting....The V6 Sprinter diesel engine is not allowed to idle for extended periods. This limitation is detrimental when you need a/c but there are generator restrictions or you are dangerously low on propane, or you have a mechanical failure with the generator or roof a/c. The Ford V10 can safely idle for hours on end, heating, cooling, and battery charging, all valuable if you have a baby, pets, or health/respiratory issues.
You decide what your priorities are, and pick the appropriate chassis. There are some really sweet motor homes being built exclusively on the Sprinter chassis, such as the Winnebago Via, View and View Profile. Others like Phoenix USA build their model 2350 and 2400 on both the Sprinter and Ford E350. They will even build it on the heaviest duty E450 upon request for a nominal fee. People who request an E450 for a small motor home, tow heavier things like for example, a multi-horse trailer. You can even special order a E350 & E450 4x4.
There is so much cool stuff offered in recent years, and even more anticipated with the upcoming Ford T-Series chassis. The general public hopes it will become available for the RV industry. It is kind-of like a Sprinter in size and fuel economy, but hopeful to be much more affordable.
The Chevy 3500/4500 Chassis
I do not understand why this chassis is not more popular. It offers more interior comfort than the Ford, but not as much as the Sprinter. It's power & weight ratings are a little less than their Ford counter-parts making them a great chassis for all but the heaviest of class Cs. They are also a little better on fuel consumption. One thing to keep in-mind, if you are counting inches to store your rig, the Chevy adds an additional 9" to the front bumper compared to the Ford. I learned that researching rigs that could fit in my 25'-0" deep garage. By default, the Ford gave me 9 more inches to work with. If you examine my motor home in my garage HERE, you will see an extra 9 inches in length might have been detrimental.
Engine Power Ratings of Ford, Sprinter, & Chevy
Ford - 6.8L-V10, 305hp, 420ft
Sprinter Diesel - 3.0L-V6, 188hp, 325ft
Chevy - 6.0L-V8, 323hp, 373ft
gmctoyman
I think a blue one is the best Class C.
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
DiploStrat
pianotuna wrote:
Hi Diplo,
What are you using for a stove?
Is Water heating diesel?
What chemistry are the batteries and how large is the battery bank?
Don't want to hijack, but:
-- Stove is a True Induction: True Induction Single
-- Air and water heat is through a Webasto Dual top: Dual Top EVO
-- Batteries are 4x300Ah 6v Lifeline AGM: Big Beasts!
DiploStrat
littlemo
Besides the obvious,(fiberglass roof with one piece endcap, no window in cabover, no leaks, chassis choice, etc.) you need to look at space planning, floorplan, how many people you will need sleeping room for, basement storage. You need to go to RV shows with family and just look, look, look to see what works. And get on this forum and read and ask lots of questions.
