Where to buy valve extension
johnnydp1
My motorhome has 22.5 inch rear dually tires. On each tire I have a stainless steel braided valve extension piece that is 13 inch long. On one inner tire, the extender had a small leak. I want to purchase a replacement but can't find a site that sells them.
Can someone send me a link please?
12 REPLIES 12
ncrowley
Another strong vote for one piece valves and not extensions. We were having lots of problems with the extensions. We purchased Borg dually valves and have not have any more problems.
Nancy
Newmar Northern Star
wa8yxm
So far my Dually valves have been there 2 weeks. no sign of leaking. Only issue is the tire store now has a "Divit" in their parking lot (They goofed and . Well it's funny now.. Was not at the time but no damage save to the asphalt)
Look good. Work good. And checking tire pressure or adding air is easier than it is on my car. Can't beat that. .No wrench needed.
These are teh "Solid valve stems" folks talk about they are custom made for your make of vehicle (proper bends and so on or so they think.. one of mine needed a bit of "Adjustment" but not a problem.
doxiemom11
Ours come straight out thru holes in the in the wheel. We bought them and had them installed at a truck shop about 7 yrs ago. So far no leaks or problems.
Fleet_Man
My MH came from the factory with plastic like/phenolic valve stem extenders. Never had any problems or air pressure loss using them. I bought a set as spares but never needed them, they are available through WBGO.
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
10forty2
Best money I've spent so far on one project was the solid valve stems. In 3 years running now, I haven't had to add air to my tires. Before, with the extensions, I had to add air every time before a trip. I still check the pressures and I still perform a visual inspection of the tires before every trip, but I don't worry about losing air pressure like I used to!
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
CA_Traveler
It's common for mfgs to have a short rubber valve stem installed the same way for all tires. When mounted on the front that stem points out so access is easy. For the inside dually that stem also points out but it's behind the outer tire. Then for the outer dually the stem points in. Hence access to both duallys is more restricted.
So to correct that situation they install less reliable extensions at your cost.
2014 Grand Cherokee Overland
Bob
wa8yxm
Extrenders... any truck stop will have 'em
Recommendation (This takes a tire stop to install) DUALLY VALVES Google 'em
I just put those on my Duals.. WelL Belle Tire put 'em on.
Oh man are they nice. and this is not an "Extension" but a new valve stem.
kmb1966
BORG DUALLY VALVE
imgoin4it
I have solid valve extension that extend straight out through the hole in the out side wheel . Never had one leak. Can get them at most truck tire dealers
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
STBRetired
X3. Ditch the hoses and get the Borg dually valves.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
jplante4
Ditto CA Trav. Nothing but trouble. I've had them leak and the rivets pull out of the hub and flail around.
What you want is long tire valves. Any truck tire place can install them.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
CA_Traveler
I don't recommend extensions because they are more prone to leak as you found out. Instead install a dually valve kit like the Borg dual steel valves. Yes it will cost more.
Bob
