White water hose bulging ??
supercub
My fresh water hose is starting to bulge a little in a couple of places, is this a sing of weakness? Is it time to replace it?
Thanks
Brian
15 REPLIES 15
ChooChooMan74
I only use Teknor Apex 5/8 neverkink hoses. 1) Made in USA and 2) One of my Rail Customers.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
rv2go
I had to replace my 1/2" x 25' ApexNever Kink RV hose last year. Not because it burst, but it was 10 years old and would kink while rolling up. The Apex NeverKink is guaranteed for life not to kink. I contacted Apex and they gave me instructions on how to get a new, free replacement.
I use a pressure regulator set at 45lbs connect to the faucet.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
supercub
I have a new hose I've never used, so will change out the old one. The old hose came with the RV when I bought it 2 years ago, so I don't know much use it had before that. Thanks for the feedback.
Brian
nevadanick
Not always a sign of a cheap hose. If its in the sun and its warm or hot out the water expands and the hose grows when there is no flow. They arent made for hot water.
barmcd
jswat wrote:
I have quit using the white hoses you get at Camping World (and Walmart). I ordered a couple of hoses through Amazon which are blue in color and are safe for drinking water. On those white ones, they aways fail around the connections, some of them only lasted me for a couple of hook ups, others lasted longer, but all fail. And yes, I do use a pressure regulator and the blue hoses have not failed after a couple of years of use.
I always get leaks at the union of the connector and the hose before I get a hole in the hose itself. I even went to the quick connect type, they last longer, but still eventually get a leak.
jswat
jetcare
2oldman wrote:
It's a sing the pressure is high.
2016 F-250 Crewcab 6.2L 4x4
2012 Palomino Sabre 32' Travel Trailer
Artum_Snowbird
Mine bulged just before it burst. Don't buy one until it blows, as having water into the unit isn't important. LOL
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
happy-2
Cheep Hose. At the water source install a 50-55 psi regulator then a good white hose for drinking water,Maybe quick disconnect fittings,
Sam_Spade
Busskipper wrote:
Yes replace it.
This is the only right answer.
All the rest of the discussion might be interesting or informative but if the hose is bulging it must be replaced. You can think about the other considerations after that.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
old_guy
where did you place the regulator? if at the TT then you have it in the wrong place. but once the hose bulges, it is time to replace. they have new hose out now, say it will be a better hose. it is not white it is a bluish green with very strong fittings
Busskipper
Yes replace it.
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
GX470-FMCA - Travel less now - But still love to be on the Road
States traveled in this Coach
supercub
Yes, I use a regulator, and it's bulging with it attached.
Dutch_12078
Yes, it's time for replacement. Do you use a pressure regulator at the tap when you connect it?
Dutch
2001 GBM Landau 34' Class A
