โSep-26-2016 10:53 AM
โOct-02-2016 02:40 PM
DrivingMissDaisy wrote:
I have a 2000 Winnebago Adventurer and about two years ago the fiberglass roof was sucked out of the aluminum channel by a combination of cross wind and passing tractor trailer. Drivers side front to back roof peeled up and all the foam insulation sucked out. I duct taped it together and drove home, I reinserted the fiberglass and glued secured it with urethane caulk/adhesive. Here's the kicker, I swear, there was never any adhesive in the roof to aluminum track. Both sides of the motorhome were like that. I assumed Winnebago left it loose so it could move when the motorhome flexed.
Wheel wells attached with pressure sensitive tape, most of the end cap accessories glued on with epoxy, how could we expect anything remotely resembling quality construction!
โOct-02-2016 12:36 PM
โOct-02-2016 12:07 PM
โOct-02-2016 11:44 AM
Mile High wrote:
I came across this Winnebago video that shows how the roof is installed (a little after minute 13)
roof
It makes it a little more clear to me how it is done, and emphasizes the importance of keeping that seal in good shape. I also learned it is not a moisture issue, as if the seal leaks water only goes into an aluminum channel - the issue is simply keeping that rolled fiberglass in the channel and not let it pop out under any circumstance.
Not a great design, but manageable if you understand it. Here is the sealant number and type:
Sealant E is a Seam Sealer: Part Number
094401-04-000 is a solvent-based sealer, versus
a silicone or urethane. This product is milky
when applied and becomes translucent when
curing, allowing the underlying paint or gelcoated
fiberglass to show through.
โOct-02-2016 10:56 AM
โOct-01-2016 11:33 PM
โOct-01-2016 07:10 AM
โOct-01-2016 05:30 AM
747Driver wrote:
Just because you don't see any chalk in the slot, does not mean it was never there. My 2003 Adventurer was checked yearly and was a little dry last year, but still had adhesion. Climbed up there in August, 3/4 of it was gone. Real scary. Removed the other 1/4 and resealed, good to go now.
โSep-30-2016 09:58 AM
Chris & Sharon Dellinger
'03 33V Adventurer, W20
'00 Ford Ranger Toad
โSep-29-2016 06:35 PM
โSep-29-2016 06:07 PM
โSep-29-2016 02:50 PM
KPetrick wrote:
If you would like to send me a private message with your contact information I can call you to discuss and offer you some ideas. I have over 30 years in the insurance industry.
Keith Petrick
Director of Good Sam Insurance Agency
โSep-29-2016 12:27 PM
โSep-29-2016 11:49 AM
โSep-29-2016 09:33 AM
