โDec-02-2013 05:17 AM
โDec-04-2013 07:52 AM
โDec-04-2013 07:36 AM
โDec-04-2013 07:35 AM
โDec-04-2013 04:21 AM
โDec-03-2013 08:38 PM
โDec-03-2013 05:05 PM
edatlanta wrote:Yes that is what I forgot to do!!!!!
I put mine on top of my curb side tire. I can reach it easily from the step area and it isn't where it can get wet, it is out of the sun, and it isn't able to get any false readings from my trailer.
I do have to remember to pick it up prior to moving.
โDec-03-2013 04:57 PM
BruceMc wrote:
I put mine inside the outside refer access panel. It is mounted just above the lowest vent. When the refer is running, which is when we are using the MH, outside air is being pulled into the vents, and because it's mounted just above the lowest vent and forward (away from the flamebox), it isn't subject to the heat from the flamebox.
It's out of the weather, and yet has outside air being pulled past it.
Like others, I thought long and hard before deciding on this spot. I tried many of the locations mentioned by others in the preceding posts - but was never satisfied with the results. The refer vent seems to be the best for us.
โDec-03-2013 01:13 PM
โDec-02-2013 06:10 PM
โDec-02-2013 03:12 PM
โDec-02-2013 09:59 AM
โDec-02-2013 07:52 AM
WyoTraveler wrote:rvten wrote:
I keep one in the utility compartment. To monitor freezing temps in there.
Yup. I can pick up my smart phone and find out what the outside temp is. I need to see what the temp is in the wet bay.
โDec-02-2013 07:43 AM
