12v TV/monitor.. What your using please.. No inverters
rerod
I'm looking for a TV/monitor we can use while camping and under way on the road.
I was going to simply ask "what 12v TV you removed the transformer from and are currently using in your RV".. But my requirements have changed.
I want a TV/monitor a can also watch music videos and online content from my laptop.
Iv read allot of bad reviews from people who have tried to connect a larger display from PC's and laptops..
Anyone doing this? And any suggestions as Im completely open to buying whatever it takes including a new laptop, but need to be certain it works well.
Thanks!
12 valve ram
29 REPLIES 29
MrWizard
Moderator
Moderator
Buying a tv that uses a 12v power brick is going to be the best option, for dc only use
thats what i said
I can explain it to you.
1997 F53 Bounder 36s
FlatBroke
If you positively, absolutely don't want an inverter get A Honda 2000 generator.
Hitch Hiker
"08" 29.5 FKTG LS
darsben
MrWizard wrote:
The thing is ....most tv's are not packaged and set up to operate from 12v , not any more,
If the tv has an external brick to convert the 110 volt to 12 volt (and a lot of them do) then what is wrong with just running a cord from 12 volt outlet direct to TV?
See Vizio, insignia and many other brands.
NO TV runs off of 110 volt anymore they all have a transformer to step down the voltage. Some transformers are internal some are external..
SO Please explain your statement
Traveling with my best friend my wife!
D_E_Bishop
And dedicated video monitors wired for 12v are automotive entertainment style, available in size upto 14", but only have RCA a/v input, not PC or HDMI
Search the truck stops and marine supply house to find specialized
12v equipment
BTW... A 15" laptop will use two Or three times the amount of power as a 15"
Tv
A new TV powered by inverter will use less power than the same size display laptop running from 12v
X-2 Just what I have been saying for a long time. 12VDC is usually cleaner than the 12 VDC output of a brick plugged into an inverter, in my opinion.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
MrWizard
Moderator
Moderator
12v equipment
Tv
DougE
Just what part of "no inverters" in the title of the post did you folks not understand! You're just wasting space and overloading the poster with information he specifically did not want.
BTW, My Samsung has HDMI, USB, RCA and RG6 inputs so virtually any signal source will work. Since the power wire is coax, you need to carefully strip the insulation to get sufficient ground wires to twist into a single stranded wire that you can solder or crimp into a plug prong. Not hard, just a little tedious. I also put a little shrink wrap on the excess to be sure it was isolated from the positive center wire.
Currently Between RVs
darsben
D.E.Bishop wrote:
donn0128 wrote:
No 12 volt junk tv's for me. Inverter all the way
Which 12 VDC TVs are junk and which ones are good TVs?
Most TV's are between 12-18 volts. THE ONLY difference is external VS internal transformer. Just like most desk top computers have an internal transformer and laptops an external; computers do not run on 120 volts neither do modern TV's
I have a insignia (BEST BUY) in my rig and also a Vizio. I have used my computer and DVD player on both. They both have an input for computer (or did when I purchased) and they worked fine. The picture quality is not quite as good as on a great monitor but heck I am just watching TV.
RJsfishin
Ok, you found a 12v tv, la tee da !
Now you need to find a 12v sat receiver,
and a 12v DVD, and a 12v everything else, so you can get rid of the inverter.
Good luck,.....but what the h??? for ??
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
tenbear
NashTT wrote:
We have a Supersonic TV that came installed in the TT. Didn't think much of it at first, but after plugging the sound into the cd/radio and we like it better. The sound of the tv's speakers was absolutely horrible. Adjustments made no difference. The picture is quite good especially on ota digital hd signals and blue ray. It does a good job on non-hd directv. Amazon sells these. We've never run it on anything but 12v, shore power or not. Our 2 group 27 batteries and solar can get us through a weekend of dry camping.
I did the same thing only I connected a pair of computer speakers to the Supersonic TV, now it sounds ok. Its a 22" and draws only 1A at 12v.
2010 Subaru Impreza Sedan
NashTT
"The opposite of Progress is Congress"
2013 Nash 23F
2008 Doge Big Horn Hemi Quad Cab 3.92
Reese 1000 bars-Prodigy Brake control
Jill, the crazy Rat Terrier always along
D_E_Bishop
David Bishop
2009 GMC Canyon
Roadmaster 5000
DougE
I bought a Samsung 22" LCD. The output of the brick is stated as 14.0v @ 2.5a (35 watts). I cut the cord between the brick and the tv, then inserted a weatherpack connector. I also made up a 12v power plug with a matching connector. So now I can hook to the brick and 120v source or hook to the power plug and 12v source. I can't say that there will be long term effects, but it is working with no discernible negative issues.
donn0128
christopherglen
Hit amazon, and search for:
12 volt monitor hdmi
The computer either has an hdmi / dvi output, or you can get a usb to hdmi to run the monitor.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Golden_HVAC
One of the problems with a TV screen used on a computer is the fine definition of the TV screen is not so great. A computer has much finer lines, so that letters do not look fuzzy.
I was looking at TV's at Best Buy and even asked the floor sales people what TV's would run on 12 VDC. They replied "None" they all plug into 120 volts. Well true enough, all where plugged in at the store to 120 volts. Many had a power supply that looks like the computer ones, and have a 12 volt output! So they where not well educated, and seemed not to care at all.
I used to use a 12 - 120 volt inverter and did not care much about how much power I was using. I have a pair of golf cart batteries with a 220 amp hour capacity. The 400 watt solar system keeps it full. It is probably easier to go that route. Unless you do find some 12 VDC TV's and are able to get the right adapter to run it from a cigarette lighter receptacle.
SunElec.com
They sell solar panels and controllers to shut them off once the battery is full. If you find a acceptable 12 VDC TV, you will still need to recharge the RV with 35AH daily to keep up with the propane, CO and refrigerator, and then about 75 AM more to meet all the other needs. This is about what my 400 watt solar system makes in a day.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
