Can you identify this
ddnsam
I found this in the rear storage compartment of a Carriage Cameo. I can’t follow the wires because the rear of the camper is sealed, no access. There are no markings on the outside front or back.
Approx. 3”x4”x1”
Fused power with ground wire (red & Blk)
Antenna-2” long (left side)
(2) sets of wires coming out of Bottom
There is a round projection on the top which looks like you could plug something into it but there is what looks like a plug in it. I did not try to take it apart.
11 REPLIES 11
hawkeye-08
it is NSA device to track and transmit your travels
HenryL
It's possible it's a remote control receiver that operates slides, awning, jacks, etc.
2017 Cedar Creek Hathaway 38FB2
2012 Ram CCDRW Cummins
BruceMc
I'd certainly pull the fuse to render it non-operational, to start.
It may be a video transmitter for a toad, or a GPS tracking unit installed by the (insert con-spiracy theory here)... or ???
As Wa8xym stated, you may need to perform an autopsy to determine just what the critter is and what it does.
Let us know!
2016 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
jplante4
Wireless camera repeater used when the camera is on the back of the toad???
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
wa8yxm
Yup. that is a module of the "not labeled" type or what in the electronics field is called POT LUCK
on the circuit board will be some names, and numbers and possibly an FCC ID. that last one is very informative.. GOOGLE is your friend, although this week (or at least today) it is goo{football}le.
Wet_Coast
pop the unit off the wall and see if there is a manufacturer's plate. May have website, model, etc and go from there. If nothing on the outside, you may want to open it up as well and snap a pic or two.
Googlemachine will be your best friend..
04 3500 4X4 Auto Cummins QC
Onboard air, Air bags, Pac Brake
05 Cougar 244EFS, Flexair Pin Box, Dexter Equalizers
6x6v, 900watt, 60a Renology MPPT, 2200w Xantrex, 3500w IPower Genset
VA7RKC Advanced
Everything runs on smoke, don't let the smoke out
Golden_HVAC
I was also looking at what looks like a video input on the top, and guess it might be a wireless camera transmitter, but the camera might have been removed for re-install on another RV?
My motorhome now has a wired in camera to my rear view mirror.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
ddnsam
bgum wrote:
A wireless cam sending unit?
I was thinking that but there are no cameras or mounting locations
bgum
Fizz
Try again.
The image is not there.
bgum
a red "X"?
