โNov-16-2014 12:23 PM
โNov-18-2014 09:47 AM
โNov-17-2014 12:10 PM
โNov-17-2014 12:00 PM
Big Katuna wrote:nomad297 wrote:LarryJM wrote:Big Katuna wrote:
I use mine on asphalt often so I can't drive stakes which seems like a pain anyways.
Mine has never fallen over. I just spread the legs out very far.
An Align a site is a $160 piece of un neccesary plastic.
I use Dishpointer on my iphone.
Spoken like a true "UNINFORMED" non Align-a-site owner/user. I won't even attempt to explain the advantages of something like the Align-a-site over things like the iphone apps, but having used both there is "NO COMPARISION". Try using an iphone app to site a dish between two tree branches with leaves on them and see which is easier and more effective to use.
Also, as already mentioned the Sat dish mount does not have to be "plumb" to properly aim the dish using the Align-a-site system.
Larry
Not saying that the Align-a-site doesn't work, but when used with a Slimline dish, if the mast isn't plumb, how do you obtain the correct skew for satellites 99 and 103?
Bruce
I think You have to loosen the adjustment bolts and re level it to the
Level on the Align a sight which is a way bigger pain than leveling the tripod.
The surveyors tripod levels in seconds no wrenches.
I have watched the AAS being used and I think my $5 app that superimposes the sats on my camera screen works just as good for $150 less.
I set up in tree covered state parks routinely.
I agree the TVRV setup is fine. But I'm a cheapskate DIYer.
I went a scrap yard and found a 1/4" thick aluminum plate 4" wide and 12" long.
I drill a 5/8" hole in the middle and bolt it to the hole on the tripod with an upside down 1/2 eye bolt with a wing nut. You could use a bungee thru the eye bolt to a stake or a bucket of dirt but I have never had to the tripod is so stable.
I sat the dish bracket on one end of the plate and outlined the mast hole.
I drilled three holes and bolted the dish mount to the flat bracket with J bolts.
Total cost about $8. I paid $30 for the Pentax tripod on Craigslist. I out a plastic bubble level on the bracket.
โNov-17-2014 09:58 AM
Larry
Bruce
โNov-17-2014 08:31 AM
โNov-17-2014 04:54 AM
โNov-17-2014 04:00 AM
โNov-17-2014 12:59 AM
โNov-17-2014 12:39 AM
Larry
โNov-16-2014 10:22 PM
โNov-16-2014 01:28 PM
โNov-16-2014 01:06 PM
โNov-16-2014 01:05 PM
โNov-16-2014 12:55 PM
Big Katuna wrote:
The little tripod isn't sturdy enought. The Dish mast needs to be completely plumb to get a good signal o n all three sats. Not necessairly true. Usingma tool like the Align-A-Site eliminates the need for leveling the tripod
I use and recommend a surveyors transit type tripod. It levels quickly and is very sturdy.
Mine has never fallen over. There is a wide variety of decent heavy duty tripods that work very well. The key is heavy enough to be stable in all conditions, and the ability to secure it to the ground. I use 12 inch spikes through the feet
I found a used one for cheap and made a plate to bolt the dish to out a a 4" x 13" 1/4" aluminum plate.
You can buy the completed unit on rvsat.com or something like that $150
