Laptop battery
salem
I have a HP laptop computer that is about two years old. It's been plugged in for a couple of days but shows the battery is at 1% and is not charging. Any suggestions as to how to get it to charge?
18 REPLIES 18
salem
For $15.00, it's worth a shot.:)
d3500ram
Salem, thanks for asking the question, I might look into a knock-off as well. Even though mine is old and is not supported my anyone anymore (Vista OS nonetheless)
...it still is still a working machine for e-mail, Pandora, streaming, etc.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
salem
New battery arrived this morning. Installed it and everything seems to be back to normal. Thanks again for all the comments.
trb46
d3500ram wrote:
trb46 wrote:
FWIW, Iโ€™ve ordered laptop batteries from Amazon before, and never had a problem.
I heard somewhere that using other than original mfgr batteries is not the best for a laptop... I would not mind spending costs for an aftermarket one (but not the $100 for an official Toshiba brand.)
Am I being overly concerned?
It is a 12 year old Toshiba.
Iโ€™m not sure I would spend a dime on a 12-year old laptop. But if you want to, you might try Amazon or Batteries Plus.
2011 Four Winds 23A
Only 48 more states to visit!
d3500ram
fj12ryder
A friend brought over an HP laptop that wouldn't charge, and the charging light wasn't coming on when she plugged it in. We had to install a new charging port to get it back up to snuff.
Howard and Peggy
"Don't Panic"
salem
Thanks, that good to hear.
trb46
2011 Four Winds 23A
salem
Ordered a new battery, $15.00 and change on Amazon.
Dennis12
buy a new battery
Dennis Hoppert
Davidlee64
I have an HP factory charger, and it has an on/off switch on it.
wa8yxm
Batteries Plus. Take it in and get a new one.
A lot of newer HP's the battery is not easily (meaning designed to be user replaced) replaced, You have to open the case. B+ may be able to to that for you. Easy if you know how (I do) but not so easy if you don't.
I had a piece of electronic toast to practice on by the way. Nice thing about Electronic toast is you can't accidently toast it. already done.
d3500ram
When my 12 year old laptop that still works well had battery issues I was shocked at the price of a new one... I bought instead three $10 chargers to keep around the house: one each in the living room, the kitchen and office.
1995brave
Also check for a BIOS update. Our HP laptops needed an update to fix the charge issue, they would only charge to 50 percent while docked(plugged in).
