NanciL wrote:
trb46 wrote:
I bought an RCA 8GB tablet several years ago to experiment with Android. I think I paid $39.95 for it. It's very slow, has short battery life, but I was able to learn a little bit about Android when using it. I don't use it now other than to turn it on occasionally to check for system updates.
Do you think it would be any good for what I want? Which is just getting weather reports?
And on that battery: Do you mean the battery has to be replaced often?
Or it just has to be charged often?
Jack L
Short battery life as in not much use on battery before needing plugged in to charge..
Not as in physically replacing the battery.
While the cheap price is appealing the fact of the matter is it is a cheaply made bottom of the line barely usable tablet which has no support technical or hardware wise..
What most folks are saying, spend a little more and get a better tablet, the cheap entry level ones like that are kids toys.
A better tablet will have more reliable hardware, slightly more refined OS (Android OS IS "customized" to the tablet hardware by the vendor), will suffer less freeze ups and forced reboots.
Cheap tablets tend to have very cheaply made screens with very low resolutions sort of like early CGA/VGA days, better ones will have higher resolution screens (closer to SVGA to HD). The differences in the screen quality are amazing.
If you want to give a child or young grandkid a tablet, the $39 tablet is what you get them..
If you want to be able to easily read what is on the screen, not have to reboot often then spending a little more makes sense.
I am not a fan of tablets by any means but after dealing with the $39 and even $69 specials I can tell you they are not worth wasting your money on.. At those prices there is no quality in them..
But hey, it is your time and money, waste it any way you wish.
On edit..
Here is a link for a 8" ACER ICONIA for $130..
ACER ICONIA 8"Specs are..
" 8-inch Display, 1920 x 1200 resolution, Active Matrix TFT Color LCD
Intel Atom Z3745 1.33 GHz Quad-core processor
16 GB Flash Memory, 2 GB LPDDR3 RAM Memory
AzureWave AW-AH691 IEEE 802.11a/b/g/n wireless LAN
Android Operating system KitKat 4.4"
That Intel Atom is a very stable processor that SIPS on the battery but yet is very fast, makes for good battery life, they rate it 7.5 hrs which is pretty good.
The display is full HD at 1920x1200 and overall will be a much batter tablet than any $39 wizbang deal!
As I mentioned before, the only thing I don't like about the ACRS is they do bundle a lot of preloaded bloatware APPS.. Takes a while to find and remove all those useless apps but worth it.
I do realize that you sole intention is to just see the weather, but once you have one you WILL find other uses.. My DW downloaded the Kindle app, gets FREE Kindle books..
That Acer also has a GPS radio built in, downloaded CoPilot GPS APP (free version).
Found a nice FREE Document App that allows you to open and write MS word compatible documents..
You can get FREE Adobe reader apps so you can open Adobe reader files..
You can get a OTG (On The Go) USB adapter which allows you to connect a USB Keyboard/mouse and even USB flash memory drives..
Has a Micro SD card port, allows you to plug in a Micro SD card up to 32 GB for additional documents, photos or even music..
