Rand McNally RV GPS
Buckeye_Chuck
I am considering buying a Rand McNally RV GPS model 7730. Has anyone had experience with this GPS and if so what are your thoughts good or bad?
2012 F250 Lariat 6.5ft. bed, 6.2L, 3:73 Gears
2013 Sabre 33CKTS-6
12 REPLIES 12
georgelesley
I read this forum daily to get ideas I had not thought of. That frequently happens. On rare occasions I have a thought that has not been posted. Such is the case on this thread. Both DW and I drive and find information overload a real problem sometimes looking straight ahead, monitoring both side mirrors, watching the rear monitor camera look at gps and or listen to phone directions is just too much for this old brain.
Our solution is that the driver watches the road and drivers side mirror with an occasional look at the passenger side mirror. Whichever of us is not driving monitors the passenger side mirror and camera, the rear camera and pays attention to proper lane choice as indicated by gps and or phone. Since we can actually communicate with each other because all other radios, music, etc are off in conjested areas, the driver sometimes says to the passenger "check the side mirror" or whatever he/she wants while the driver keeps focused on the road ahead.
Dividing up the duties especially in contested areas works for us.
George 20 yr USAF & Lesley
Buckeye_Chuck
Thank you for the replies and the opinions that I requested. I appreciate them. Sarcasm, not so much.
2013 Sabre 33CKTS-6
Us_out_West
rr2254545 wrote:
Us out West wrote:
rr2254545 wrote:
Go with Garmin RV unit you will be much happier like me
No mine is better...no mine is better.....
Care to talk about why yours is better than someone elses preference?
No i do not
Then thanks for your contribution.
Our Trip Journal
2012 Jayco Pinnacle (View)
36 KitchenPantryTripleSlide
MorRyde pin box and suspension, Curt Q24, Dual Pane windows, Auto Levelers, 2 AC's,and more.
2009 Silverado 3500HD 4X4 (View)
CC, Dura-Max 6.6/Allison,LB ,DRW,Amer. Tank 65 gal. Aux Fuel
rr2254545
No i do not
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee
492 Campgrounds,107K miles driven in our Winnebago motor homes and 2360 nights camping since we retired in July 2009, 41 National Parks
Us_out_West
Our Trip Journal
YC_1
I have two of them. I broke my first one but repaired it after buying a new one. I will not leave home without it. All of them have some warts but the benefits of hitting a couple of buttons and finding a truck stop along the way or rest stop is fantastic. I use the check list every time we leave a camp spot. Of course it is my own check list. They could improve the way it is edited but it works well.
Using this GPS next to my smart phone with the Waze app makes things really relaxing. As we decide where we want to spend the night while traveling my wife does some research and then tells me the name of the campground she wants to go to. Using the simple features of the points of interest I can have it up and going in the gps in a matter of seconds.
The height setting warnings is a great help. They could use a bit better graphics but for the price, they work very well. The Dock software on mine seems to work well. I update about every 6 months.
As someone mentioned, having the digital speed showing as well as the speed limit and a warning if you go over by whatever you set it at is handy.
I have had many many Garmins and all were great. Having this one that is built around rving is really a benefit.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
Nicholsfamily05
We have the 7725 model.
No serious complaints about it.
We like the fact we can put in the length, height, weight and how much propane we are hauling.
It has been good so far about routing us around things and ways we shouldn't go.
We also like it because you can switch between RV mode and Truck mode.
We also like the fact it has a second input for a back up camera that we used for a camera near the hitch to help us hitch up.
The only thing I could even think about saying is wrong with it is the screen touch. It's not very sensitive and sometimes if you say press the A button it pushes the one next to it. You get used to it and make the changes as you type on it.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
2oldman
This person
rr2254545
2014 Jeep Cherokee
n7bsn
The campground directory is very good, the user interface is not, in fact might be the worst on the market.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
Finally_Time
I have a Rand McNally 7730 with a 7 inch screen. The length, height, and weight for the RV or RV plus tow or towed vehicle can be set. The GPS will then route you away from low tunnels and bridges. It can be set to avoid small roads and dirt roads. There are lots of other settings for warnings about going over the speed limit, approaching sharp curves, construction zones, etc. I travel by myself; the cat is no good about reading maps and gets bored with the smart phone or tablet, so I appreciate the step by step directions and the visual showing which lane to get in for exits and interchanges. Also the motor home speedometer is hard to see it some lighting so I find myself using the GPS speed indicator โ€“ much easier to see. I am very happy with this GPS and now that I am used to it, I find it easier to use than the Garmin in my car. There is a learning curve though, it takes a while.
'17 Tiffin Breeze 31BR, '13 Honda CR-V
Ready Brute Elite Tow Bar & Brake System
Sgt472
I'm not sure about that model but I have the newest RM software in my coach dash radio and there "Dock" software is not user friendly. You have to physically plug your unit into internet connected PC to get updates and half the time it freezes. The trip planner software is decent when it works. The actual GPS navigational software does work good and seems to be acurate
Chris
