Here are my Libre Office results from 2 straightforward files. Latest version 4.4.4.3
102 page Word 7 docx file with a 2 column table of contents, Heading 1, Heading 2 and Normal text and page numbers. Nothing fancy just information Iโve connected on rv.net. It loaded in an acceptable 5 seconds vs Wordโs 2 seconds. The TOC has some kind of 2 column outline mode but only the left column is used. The body has no page numbers which is unacceptable. The Libre document now has 140 pages with lots of text that are not in the Word document. It is text that I recognize and likely deleted. I may have started with a similar but different file but made a lot of changes. Perhaps the data is saved as hidden text in Word? I assign this conversion a grade F - total conversion failure.
I guess the Libre Writer has some value but the conversion is totally hosed.
14 column x 9501 row Excel 7 file. The file is collected solar data with 2 small graphs and very minimum formulas to compute. The Excel file took 50 seconds to load with Libre vs 3 seconds for Excel. Saving the file as a OCD file it then took 30 seconds to load. Briefly the data looked OK. Grade C.
2014 Grand Cherokee Overland
Bob
