Spinning "wheels" on Firefox tabs?
Ramblin__Ralph
I'm using FF28.0. I have it set to come up with many tabs open every day. However, today almost all of the tabs continue to have the site icon spin after reloading the site. I started FF over an hour ago and many are still spinning.
There are a few tabs, however, that don't have this problem. I wonder if there is some site down that these problem pages include in their HTML code?
FYI, I'm using AdBlock.
Thanks,
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Bilstein Shocks, TorkLift Stable Loads, 100 Ah LiFePo4, 225 watt solar
My RV Travels Webpage / Yearly Campsite Map / 740 Campsites / YouTube Videos /
Instagram
10 REPLIES 10
garry1p
I also X it out when it seems to be hung and then click the "reload the current page arrow" and that usually fixes it.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
Sfla2
everybody knows that ,its when they never load or stop we're talking abt
98 Coachmen "C" Santara Model FL (Front Lounge) 30.4
Ford V 10 Super Duty (same as E 450)
1775
Those spinning wheels are the pages loading in the tabs - normal for Firefox.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
Sfla2
went to chrome same thing must be GS CW Marcus server
wa8yxm
The Worm Oroborous (As best I can spell it) (The worm that eats it's own tail) indicates that FF is still trying to load the site, but has not yet finished.. Some sites seem never to finish..
But... If the site is down. .That happens.. IF you open too many tabs at once you can also overload your connection.. and that happens.
I have found that clicking on the tab, then on the X which is on the address bar (NOTE you may have to add that one) to stop the tabe.. then clicking on the circular arrow on the address bar to re-load. Often loads the sites when I'm on a bandwidth limited connection.
Just now I'm on 4G which means they load faster than I can get my hand off the rodent.
Ramblin__Ralph
This problem just came up this a.m. and I remembered I'd installed Garmin Express (needed for a new GPS) yesterday. It has a "tray program" that is always installed. I took it out of the start-up list and re-booted. Bingo, back to normal operation, w/o any spinning wheels. Haven't re-enabled it yet, to see if that's really the problem, but I'm pretty sure it is.
Thanks for the various ideas, though.
Ralph
Ralph
Instagram
AmericaOverland
Nope... It basically means that you've run out of main memory, and you need to shut FF down and launch it again... FF has never really fixed their memory leak problems. If you look at the processes of FF, you'll see over time that the memory allocated to it grows over the course of the day. Really horrible about this. It's possible that the latest version of FF (at least on the Mac) appears to have addressed the memory leak situation. I haven't had a chance to observe the processes of FF at the end of the day, but it has behaved a LOT better than older versions, which would force me to "force quit" FF 2-3 times a day. Now, I don't get what I call "beach-balled" and froze up. It's a PITA, but go ahead and update to the latest and see if it solves your problem.
darsben
On of the sites may have JAVA SCRIPT hung up waiting for a response from you to either continue the script or stop the script. This could be hidden in one if the tabs or behind firefox
Traveling with my best friend my wife!
WrongWayRandall
Scripts that are not allowed to run, or do not finish running, can cause this. Some plug-ins will interfere with scripts and you will get the ever-spinning wheel.
- Randy
1975 Westfalia Campmobile "Backroads Wanderer"
2014 Rockwood A122 hard side popup
2oldman
Slow internet connection.
