โOct-23-2015 01:10 PM
"I'm not insensitive, It's probably that I just don't care!"
โOct-24-2015 03:54 PM
โOct-24-2015 12:23 PM
Shipper wrote:
. . . if the RCVR 612 HD solo DVR I'm getting won't work then can I not use a DVR on my Dome with Dish? Need some advice here pretty quick-the installer is due Monday.
โOct-24-2015 10:15 AM
TechWriter wrote:
Your Winegard dome supports two single-tuner receivers -- the VIP211, not a dual-tuner receiver.
If you really want DVR capabilities with a dome, stick with DirecTV.
โOct-24-2015 08:24 AM
Shipper wrote:TechWriter wrote:Bill.Satellite wrote:
You can do 2 DVR's with a dome as long as you have the additional splitters (DP44 IIRC).
If you mean one of these guys (a DPP44 below), it's not needed.
Current rooftop domes (Winegard RoadTrip Mission, King Dome KD2000/3000, TracVision RV1 & A9) all support 2 (or more) receivers without external switches.
I have two cable inputs from my Winegard dome, but only currently using one with my DirecTV single receiver setup. When I switch to Dish with the two tuner DVR do I connect both input cables into the one DVR or is only one cable needed with the other cable used for another receiver?
PS: Just found out that my DirecTV incentives expired, so I'm more motivated to switch to Dish.
โOct-24-2015 04:19 AM
โOct-23-2015 05:32 PM
โOct-23-2015 05:03 PM
โOct-23-2015 05:02 PM
โOct-23-2015 03:39 PM
โOct-23-2015 03:18 PM
Shipper wrote:
Thanks for the replies! Can I get two standard (dual tuner) DVRs from Dish (no Hopper)?
โOct-23-2015 02:29 PM
Shipper wrote:
Thanks for the replies! Can I get two standard(dual tuner)DVRs from Dish (no Hopper)?
โOct-23-2015 02:14 PM
โOct-23-2015 01:58 PM
