***Update*** Adding Canadian service to Verizon plan
loggenrock
So here's an update on how this is going! Two words - very well!
Global service started when supposed to - keeping data off roaming for now, as access to WiFi is good. Placing calls without issue. Plan allows for 250 min. So far so good! ST
Anyone have any experience with adding Verizon's global roaming for a month or two to your existing service? Which carrier does Verizon team up with? Will be in the Maritimes - looks like Virgin Mobile, Bell Mobility, or Telux have the best coverage there. Thanks for your input! ST
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
26 REPLIES 26
ktmrfs
CA Traveler wrote:
sdianel wrote:
I also added data to my Verizon Mi-Fi for my laptop. You buy it in packages. I think it was $25 for each 100MB. When you go over 100MB, they bill you another $25 for another 100MB.
Big bucks considering I pay $80 for 10GB for US data.
yup!!! Data in canada is expensive if you have a U.S. based carrier.
I just did the verizon voice/text plan for $10/month while we were in canada. prorated based on the actual time we had the plan. started it the day before we left, cancelled the day after we got back, prorated for the actual days used.
2011 Keystone Outback 295RE
CA_Traveler
2014 Grand Cherokee Overland
Bob
sdianel_-acct_c
I added Global Roaming on my cell phone which included Canada with no problems. We used it in Banff and Lake Louise area with no problems. When I returned to the US, Verion cancelled Global Roaming and prorated the last month.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
CA_Traveler
Call Verizon before you enter Canada and add the phone for $15/month, otherwise the same plan. Turn off data on the phone. The only data we found was very expensive so we used free WiFi when available. Standard disclaimer: Do not use WiFi for financial accounts, etc.
Bob
obgraham
Verizon's Globality thing is very difficult for short trips. Just back from South America for a week, where I wanted to add Global. But my billing rollover date fell in that week. So I had to add all of the month before and all the month after the trip. Over $150 by the time they got through, despite most of an hour hassling the phone service guy..
I said no thanks and relied on local wi-fi instead, and left my phone in Airplane mode to avoid it trying to hose me.
As it turned out I was able to use Skype to call, though it was sometimes iffy.
ktmrfs
wxtoad wrote:
We were able to add Canada to our VZW MORE EVERY UNL TLK&TXT plan for the month we spent on Cape Breton. Had no hassles either adding it or stopping it when back in the US.
WxToad
same here when we went to alaska. However it is voice and text ONLY. Data plans or data useage is outrageously expensive. we just turned off mobile data while in canada. IIRC it was $10/month for the talk and text in canada.
MrWizard
Moderator
Moderator
Swapping SIMS is an AT&T, T-Mobile thing, not so easy on VZW
I can explain it to you.
1997 F53 Bounder 36s
n7bsn
My old job required us to work on both sides. Several of my (former) co-workers bought "Canadian" SIM cards and would just swap SIMs
No I don't recall phone models or which company
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
wxtoad
WxToad
2005 Lazy Daze 26.5 Rear Bath
NE13
accsys
Maxi Signal wrote:
I have had North Americas choice plan for years. Great for voice . Data is a no go. I live on the border and go to Canada quite a bit.
I also used the North American plan on two previous visits to Canada but I don't believe it is available anymore. You may be grandfathered in on this plan since you have had it several years. We are getting ready to enter Canada for five weeks the end of June and the current options don't appear to be very good. You can check the Mexico and Canada Global Plan but it is nowhere near the old North American plan.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
Maxi_Signal
jrs1871
I am not sure you can. We tried to add Canada to our Verizon plan for a trip a couple of years ago. When I had asked about it a month or so before we left, the staff at the Verizon store said no problem. When I tried to add it, just before we headed to Canada, they said no can do. So I don't know if I just got bad answers from the Verizon folks or if it is not available. We ended up buying a cheap prepaid phone so we could keep in contact with kids. And the per minute rate that the Canada plan charged was not cheap. Probably would have been just at cheap to use our Verizon phone and pay the roaming charges.
