Aug-01-2015 08:48 AM
Aug-02-2015 04:59 AM
Aug-01-2015 03:10 PM
GordonThree wrote:x3rwbradley wrote:
Just be mindful, the connector will cost you a loss of about 1db and the cable the Wilson's come with has a reasonably high loss as well. Just by adding an additional 10' may cost you as much as 2-4db as well. This on an amp that provides about 25db gain, you will loose up to -5db off this type of setup. If you are going to be in extreme fringe, I would not recommend this setup. If you are just in areas that have low signal and you need a little boost, than this is a great clean way of doing it. There are lots of threads out there that have alternate setup's that you may like as well. For mine, I came thru the fridge vent in the roof and drilled into a shelf beside the fridge and mounted the amp on the shelf. This avoided any additional cable or connectors, looked clean and I still had about 4' of slack left. Also factor in that the antenna must be 6' away from the cradle in your setup.
x2 on this - cell phone signals are so weak, every connector and foot of cable is just killing your signal - it's not like cable or broadcast TV
Aug-01-2015 12:57 PM
Aug-01-2015 12:28 PM
Aug-01-2015 12:14 PM
Aug-01-2015 09:43 AM
Aug-01-2015 09:35 AM
Aug-01-2015 09:27 AM
MrWizard wrote:
SMA female face plate bulkhead mount
They do exist
I think this will do it
Get these and a blank wall plate cover
Drill hole in cover , mount in cover
Aug-01-2015 09:07 AM
