โNov-05-2020 08:35 AM
โNov-08-2020 09:26 AM
pauldub wrote:
You really don't need to turn your computer off.
โNov-07-2020 12:31 PM
โNov-07-2020 12:13 PM
AsheGuy wrote:
I don't believe any of the "experts" that have commented on this thread so far have addressed the fact that current Windows 10 versions default to the user of a new PC signing up for a Microsoft account with password. If the user of a Windows 10 PC is using a Microsoft account on their PC, they have to login with its password or they will not be able to access their content that is in the MS cloud rather than on their PC. Many new users are not aware enough of this to reject the MS default of using a Microsoft account and instead setting up a local account on their PC that will allow logging in with or without a password at the user's choice, and result in their documents being on their PC and not the MS cloud.
That leads to the question to the OP, which kind of account was set up on your PC. A PC can be setup with both account types and if that is the case for the OP, maybe that is what is causing the confusion.
โNov-07-2020 06:07 AM
โNov-06-2020 06:57 PM
wa8yxm wrote:
Once you get in use a PIN.. for example 1342
Many on the forum (Mostly older men) will know where I got that one from
(NOTE that is NOT my PIN)
โNov-06-2020 01:48 PM
โNov-06-2020 12:41 PM
AllegroD wrote:
Use a password.
โNov-05-2020 04:55 PM
โNov-05-2020 10:59 AM
Latner wrote:
While logged into your computer, pull up the Run window by pressing the Windows key + R key. Then, type netplwiz into the field and press OK.
Uncheck the box located next to Users must enter a user name and password to use this computer.
Click the OK button toward the bottom of the window. This will prompt an automatically sign-in box to appear. Enter your username and the new password you created earlier into the fields provided.
Click OK and choose to restart your computer.
โNov-05-2020 10:31 AM
โNov-05-2020 08:46 AM
