azdryheat wrote:
Sounds like you need to separate the two computers and create a new MS account for her.
No.
Sounds like an recent Update may have reset or changed file and folder permissions in order to close a security hole.
With Win10 MS tightened up file permissions considerably when using multiple users on the same PC, in times past you used to be able to simply search through the user folder and open and edit any document. Not so much now without the Administrator password.
Additionally with MS version of Cloud computing (IE One Drive) permissions can get pretty fouled up between users.. So if both PCs are set to sync the shared files and folders on One Drive there may be additional steps required to fix that foul up.
See
HERE for more ideas on resetting/changing file and folder permissions.
HERE is another link with some step by step instructions that may be helpful (note, I have not used or have any idea if the "software tool" that is offered is safe or works so user be aware!).
For a more expansive search on file and folder permissions see
THIS search..
For OneDrive permissions you can check
HERE
