Windows 7
bgant4
I am still running windows 7 but I read that MS is having problems with it. Any comments here?
20 REPLIES 20
bob213
donn0128 wrote:
The big issue with Win10 is the forced auto update. If your traveling and using a cell based hot spot it could cost you literally hundreds of dollars.
Google is your friend. Try here:
clicky
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
WyoTraveler
The other choice instead of windows 10 is Linux Ubunta
donn0128
coolmom42
Win7 is a good system. At some point it will no longer be supported, but right now it's fine.
I dreaded switching to Win10, and put it off for a while. My daughter accidentally turned on the "automatic" upgrade on my desktop. Turns out it was a non-event. I deleted some of the tile things that show up beside the start menu, and the start menu looks a little different, but otherwise no big changes. All my taskbar buttons and files are intact.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
MNGeeks61
No problems here. The problem with it is Microsoft was ... ahem, never mind.
You're probably hearing about
this ****
and this
I work in a very large corporation (that shall remain nameless) and we have literally hundreds of thousands of Windows 7 machines. No more issues than the normal ones.
Your mileage as a home user may be different, as the company decides which patches and updates are critical compared to MS, and we can deploy them in a different manner than Microsoft can.
turnipbwc
You think you have problems, try windows 8. It really sucks..................
'95 Dodge Roadtrek 190 Versatile,
'01 Chevy Silverado 1500 4x4
'02 Subaru Outback LT
