Sep-01-2014 06:03 AM
Sep-08-2014 09:19 AM
Sep-05-2014 10:41 AM
Sep-03-2014 10:35 AM
Sep-02-2014 10:00 AM
Sep-02-2014 09:35 AM
Sep-02-2014 09:28 AM
someone did suggest getting the septic tank drained more often if the black water or grey water are drained into it,
Sep-02-2014 06:40 AM
Sep-02-2014 06:10 AM
Sep-02-2014 06:00 AM
Sep-02-2014 05:42 AM
parkmanaa wrote:
Another thing you might consider. All black water MUST be held until the tank is full, then dump at one time. While it is customary for RVers to leave the gray water valve open all the time, you could also close this one and dump all at one time.
Then, set a time of night when your house usage is minimal and dump both tanks.
Thru my experience of living with septic systems in the past, I believe this may be a viable solution.
Sep-02-2014 04:48 AM
patperry2766 wrote:
Seems like the easiest solution would be to have the home's septic tank pumped out more often for the next 1 1/2 years while she is living there.
Sep-02-2014 04:41 AM
Sep-02-2014 03:28 AM
Sep-01-2014 10:24 PM
