Gas Grills?
bazaarsoft
Looking for suggestions on grills: what does everyone do? We're thinking of getting a propane grill that we can hook to the outside gas connection. If that's what everyone does, which grills are best? Any that have problems?
2011 Nissan Armada, 5.6L V8
2012 Dutchman 296FKS
42 REPLIES 42
paulcardoza
The Weber Q series is definitely a popular choice among RV'ers. You see them everywhere. For my taste, the Q doesn't get hot enough. We like our steaks and burgers charred on the outside and med-rare inside. We had the Q-120 and it just would not do that for us.
After a lot of searching, we settled on a Solaire carryout. It's an IR grill that is the hottest I have ever used. If you like to slow cook anything on low heat, this is not the grill for you. Even at it's lowest setting, it is really hot. For us, though, it is perfect.........
Paul & Sandra
Plymouth, MA
2014 Heartland Cyclone 4100 King
Ron3rd
allen8106 wrote:
sch911 wrote:
Weber Q100, 120, 200
And the gas adapter.
Ditto
That setup works fine if you have an external tank to connect to, then you're good to go. If you carry an extra 20 gal tank (or smaller) for bbq, it's fine.
Won't work with the quick disconnect fitting on trailers.
Equilizer Hitch
Honda EU2000
allen8106
Ditto
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
mleekamp
we use the COLEMAN ROADTRIP grill....it folds up and is easy to move. cast iron grates ensures they won't rust out as cheaper grills do. uses the 2lb. propane canisters...but you could do a hook up to larger tanks. Bought it at basspro but I know they are on amazon and other places.
goducks10
Been using the Weber Q100 for 3yrs camping and at home. Very solid w/o thin metal. All cast material. Weber grills are more expensive than the rest but seem to have the better grilling and durability. We had a Weber Genesis model they don't make anymore for yrs and last year gave it to one of our sons since its just the wife and I at home we just use our Q100. You will need to remove the Weber's regulator if using it on the RV's BBQ gas line.
x96mnn
I do not think you can go wrong with a Weber and is what I use at home and planed to buy for the camper. That was until my neigbur who camps with us showed us this one in action.
http://www.costco.ca/Nexgrill-Portable-Propane-Grill.product.100030478.html
Cooks even, runs much hotter then any smaller BBQ I have seen and all parts are stainless steel. Below are pictures of my conversion from the tank connect to the quick connect.
http://s1265.photobucket.com/user/x96mnn/library/RV%20BBQ?sort=3&page=1
paulcardoza
Says it's made from cold rolled steel. Can't imagine it'll last very long........
2012Coleman wrote:
Check out this grill - you can use propane, gas or wood, and it sems to be very portable. Thinking about getting one. Also found on Amazon.
Paul & Sandra
Plymouth, MA
2012Coleman
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
Doug_and_Cassi_
Weber Q 100 is what I carry. Reasonably compact and best I've ever used. I carry a 1 gal propane tank.
Madmak
I have a Weber Q 220 that I haven't yet used! I can tell you, however, that after a whole winter of checking reviews the Webers are by far the favourites with many, many faithful users.
Bighorns
Ramblin Recks wrote:
Ron3rd wrote:
Weber 200 is hard to beat. I also recommend the Weber rolling cart accessory. It fits both the Baby and Full Size Weber Q.
If you go with a Weber, here's how I converted mine:
Weber Conversion For Regulator Removal.
X2 use it on the road,tailgating,and at home. Great Grill.
Thanks for the info. Just ordered the parts for mine!!
2011 Duramax 3500HD Dually
2012 Keystone Cougar 330RBK
Schertz
Check out an electric grill. Only uses about 1500 watts; I carry an extension cord and plug directly into the 30am service with adapter or 110 if available at power pole. Add smoke chips container and SET the thermostat so you move about, visit, etc. without constantly watching for flame ups and overcooking.
Amazon and others has several brands priced under 100.00 with good reviews.
yes, I also carry a small charcoal grill but rarely use it.
2013 Holiday Rambler Endeavor
2010 Cadillac SRX
bazaarsoft
I'm getting the feeling that we'll probably want to get a weber... ๐Ÿ˜‰
Thanks for all the great feedback!
Ramblin_Recks
George and Ann
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB ,4x4,3:73, Retrax Pro, Q20
2014 Cedar Creek, 36CKTS, 640W Solar, MPPT60, Magnum 2000
Retired Army, but still working....until 2016
Roundtwo-40
weber q 220
2013 Jayco Eagle 328RLTS w/15K AC
2013 Ram 2500 CTD CC 4X4
Equalizer 14K,PI PT30C Surge
