learn me about tires
Jebby14
hey all. the tt I bought has old rubber on it. whats everyones preference and any ideas on a good place to get um (im in Ontario Canada) trailer is a 1991 powler 19E (4 down 2 spares around 4500lb loaded)
Q: Whats brown and sticky???
A: A Stick....
9 REPLIES 9
Sport45
The C and D tires probably have the same number of plies. The "ply rating" thing is a throwback to the old bias ply days...
โ€™19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
westend
Jebby14 wrote:
trailer runs around 4500lb loaded. 4 wheels down I should have plenty of capability with a c load rating right?
Yes but if your rims are rated for a higher air pressure (65 PSI), why not get "D" range as you'll gain two plies and probably won't pay more.
'03 F-250 4x4 CC
Jebby14
A: A Stick....
352
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
westend
You're going to get a lot of recommendations for Maxxis and LT tires. Both are good suggestions. I'd suggest to cross the border and visit a Discount Tire (or similar) and see what they stock. I put new shoes on mine two years ago. I bought Carlisle Radial Sport RH in load range D. The price was right and I have a bit of faith in their construction. They are also stocked across the country so if I need another one, I won't have to order and wait for a tire.
'03 F-250 4x4 CC
fla-gypsy
I've had good results with Maxxis tires. Get the heaviest rated tire available for your wheel size.
bsinmich
Go North. Even with the exchange rate prices are lower in Michigan. We have only 6% tax in Mich compared to your 15%. That will help on the exchange rate. I would get the heaviest duty tire possible for your weight. I was in Windsor last Friday.
1999 Damon Challenger 310 Ford
Grandpere
When we had trailers, I went to LT (light truck) tires, 1 size larger, and the highest load range. As for brand, back in the day, I mostly used Atlas truck tires or if they were not available Goodyear tires. Now days I would go with either Kendra or Maxxis tires.
Berniece & Russell Johnson
Lil'Bit, a Netherland Dwarf Rabbit
1987 Southwind
1995 Ford F150 Supercab
Life in the fast lane? No thanks, we will stop and smell the flowers at every opportuity
Grit_dog
Navigator
Navigator
Etrailer.com had the best prices I could find last year.
Get the heaviest tires you can. Presume you have 14" wheels, there are a couple D load 14" tires available.
