Propane tanks cover
MikeInOregon
I just purchased a 2015 Creekside 20FQ. I noticed that the plastic propane tanks cover is not secured to the tanks or the trailer frame, it is being held down only by its own weight. It looks like an upward gust of wind could lift it up and off of the tanks. Should the cover be secured to the tanks or trailer frame?
2015 Ford F150 3.5L EcoBoost
2015 Creekside 20FQ
ProPride Hitch
19 REPLIES 19
opnspaces
Navigator II
Navigator II
As said if it seems too loose pull it off, loosen the wing nut, slide the tanks apart a bit, and tighten the wing nut back down. Mine fits fairly snug and I have to rock it side to side to get it to come off.
wbwood
No problem with the hard plastic covers. They stay snug on there.
Brian
2013 Thor Chateau 31L
atreis
I had a cloth cover on my tanks for about a year - the mice found it to be a nice place to nest so I ended up removing it.
2021 Four Winds 26B on Chevy 4500
mobeewan
Like PawPaw I can move the tanks farther apart so the cover fits tighter.
bikendan
dewey02 wrote:
Lots of things to worry about on your trailer. This is not one of them.
ours has sat unsecured, on top of our tanks, for over 8 years now and has never lifted off.
pitch
x3
Bumpyroad
cyntdon2010 wrote:
Our propane cover has a small bungee cord at the bottom there should be 4 holes.
yep, same here but only 2 holes.
bumpy
rjf7g
Great way of putting it...
1999 American Cruiser Class B
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
DutchmenSport
My pop-up had a soft cover (single tank). Almost lost it once, but the hose went through a hole in the cover and it wrapped around the hose. It would never be "lost" unless someone unzipped the top, unhooked the propane line and then took off with it.
All 3 of my TT had double tanks with a hard plastic cover. Never ever even came close to loosing it. It's not tied down.
PawPaw_n_Gram
When you loosen the big wing nut holding the tanks down, there is a little movement in tank position possible. I move my tanks outward a bit to make the plastic cover snug. It takes some effort to overcome the friction and pull the cover off.
However, on my previous TT, a tight fit for the cover interfered with the L bracket for the W/D hitch, so that plastic cover was very 'loose' fitting.
Never had a problem and have never heard of anyone losing one, though I'm sure it happens eventually somewhere.
Full-Time 2014 - ????
โ€œNot all who wander are lost.โ€
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
wa8yxm
A lot of folks have those covers, dang few see them blow away (if any).
I had a fabric/vinyl cover on my TT but it was more pain than worth. I am not sure you'd not be happier long term with no cover at all.
jake2250
My hard plastic cover fits snugly but I ran a couple of zip ties together at the bottom (mine came with two tabs at the bottom) for a "Just In Case" measure!!
dewey02
mbopp
My hard plastic tank cover is free-floating. Haven't lost it in 2 years.
I did lose a single 20# soft cover off my pop-up though.
2019 F250 XLT Supercab
Just DW & me......
