Stupid question about soft spot in floor
Huckster1037
Tent camper converting to TTing and doing a lot of research and reading but still a lot to learn. Question number 1: Still looking for my first TT. Narrowed it down to a couple, and my first choice is a 2006 Outback 29BHS. Inspection revealed a soft spot in the floor (about 8" v 12") near the front right corner. No visable signs of leakage anywhere. Dealer is reputed to be the most respected in the area (mid-south) and says it would be fixed by re-inforcing the area. Is this an acceptable "fix" or should I just forget about this one? Thanks - I have gleaned a TON on info from these forums
14 REPLIES 14
djsamuel
I am still wayne_tw wrote:
sorry try this
http://www.youtube.com/watch?v=xx0SPexRHgo
I was waiting for that guy to fall through the roof!
2013 Camplite 21BHS Trailer, Ram 1500 Tow Vehicle
Bob___Ann
I would keep looking. If it has rot there it could have it elsewhere.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
I_am_still_wayn
Check out this video. It may have you thinking twice about that RV and its soft floor.
http://www.rv.net/forum/index.cfm/fuseaction/post/forum/28/thread/27399368/parent/27399368.cfm
I'm not getting a video, just the reply screen.
sorry try this
rrohrer
A soft spot usually means it leaked somewhere and got wet. The leak needs located and repaired before you fix the floor. These kind of repairs get pricey. Stay away unless the price is well discounted(which it isn't).
Wagonqueen_Truc
Soft=rot... No if,s ands or ors about it. In a year it will be twice as big.
uncle_t
IMHO way overpriced
2020 Integra 36U
can am spyder or can am commander
BE PREPARED- NEVER BRING A KNIFE TO A GUNFIGHT.
Old-Biscuit
Huckster1037 wrote:
Thanks guys! I guess I really knew the answer before I asked, just hoping I was wrong. The price seemed good, $10,500 and they would install the WD hitch, digital brake assist, and sway bar.
Low retail is $9,500
Soft spot could be from water intrusion OR just weak sub-floor material
Either way 'bracing' is just a bandaid fix.
Search on
gbopp
brirene
I agree with the others; walk. Other dealers will also install your equipment. Good luck!
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Huckster1037
copeland343
Walk away
I_am_still_wayn
westend
Stay away, there are better choices out there without a ton of work to make right.
BTW, thanks for reinforcing my perception of salesmen. I guess we'll hear about an honest one, some day.
'03 F-250 4x4 CC
gbopp
Personally, I would walk away from that TT. The dealer is going to put a band aid on the problem, not repair the damage. Plus you don't know what caused the soft spot. JMO
