2018 GMC Sierra Towing
Bevo10
Looking for advice on towing with a 2018 GMC Sierra with a 2" leveling kit. I have plenty of power towing but having a hard time getting it to ride correctly. Seems as though no matter what I adjust my front end seems a bit light. I have tried going from the fourth to the fifth link one my weight distribution bars and that doesn't help at all.
I had the ball and trailer measured for correct height etc. and all checks out. Any advice of what I could do different?
23 REPLIES 23
hawkeye-08
There is a sticky on setting up WDH. Get your weights, then go through it step by step. Some steps will be repeated.
Grit_dog
Navigator
Navigator
No T bars on a newer GM.
Leveling kit is generally front only to LEVEL the trucks stance.
Ben 2" LIFT would be front and rear. But it's just terminology.
Just a typical 2" spring bucket leveling kit doesn't affect handling much, at least in the Chevy/Ford/Dodges I've driven with them.
Grit_dog
Navigator
Navigator
"The trouble is that you and I are coming at this from different perspectives. You have a 3/4 ton truck, I have a 1/2 ton. Different capabilities and different towing experiences. And you said it yourself, there is a lot of missing info the OP has not provided.
And just why would you need a hitch for a TC?"
I have or have had every flavor of pickup truck out there. 1/2 and 3/4 both sitting in the driveway every night currently. The 1/2 does waaay more towing then the 3/4, currently.
I do actually use a hitch behind the TC....to tow stuff...
It's hard to explain where a guy is coming from on the interwebs, but I've been hooking and pulling trailers behind class 2 to 7 trucks since about 15 years old (never drove semi, much, few dump trucks here n there, but not a truck driver). 100s of different trucks and somewhat equal number of trailers from "normal" to "get my picture on rvnet for towing that stupid bid load with that little truck."
Yes my hypothetical numbers may not match the OP's situation, but The principles are the same though and that trailer don't take THAT much weight off the front of the truck.
Like BenK and others said, there are other considerations and dynamic loading that increase or decrease weight transfer.
blt2ski
Moderator
Moderator
A leveling kit could be a drop of RA too. Then loaded, rear squats more in either case, pulling more weight off of FA.
Grits swag of 3' of distance to hitch from RA, is probably off by 1 if not 2'. I've usually measured 5' or so in my GM trucks.
Any way, as noted, a few variables that effect Handling have not been mentioned. Hard to say what the whole issue is.
Co you kcal through front end alignment into issue, depending on leveling kit, bad shocks, axle alignment on trailer......
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
parker_rowe
BenK wrote:
A TV and trailer tongue loading...it is NOT a hard fulcrum like a teeter-toter, but compliance from the tires and suspension (AKA Squat) which adds another level of geometry to account for
Then the weight of the TV forward of the rear axle's axis of rotation. Does the OP have a standard half ton with short bed?...extended cab and that added weight...crew cab and that added weight and all of the options this half ton has up there
Another assumption is that, since the OP says 'strong' might mean it has the 6.2L, which is typically optioned with lots and lots of goodies
Hows about that 2" 'leveling' modification? What is that? Body lift, lift blocks on the rear axle, or ???
My first guess for a 2" leveling on an IFS GM truck would be a torsion bar crank/adjustment. Leveling is almost always a front end lift, since most pickups ride higher in the back from the factory.
2015 Starcraft TravelStar 239TBS 6500 GVWR
1997 GMC Suburban K2500 7.4 Vortec/4.10
1977 Kawasaki KZ1000
BenK
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
APT
While I agree in principal with Grit, math based upon estimates is poor. "4,338" trailer weight seems like a published wry weight. Could be 5500-6000 pounds loaded with 800 pounds of TW. I have no idea. Collect more data - get some facts to make better decisions.
2017 Subaru Outback 3.6R
Campfire_Time
Grit dog wrote:
Meh, maybe for you. Depending how much weight "1/2" takes off the front axle I suppose. It likely boils down to what your used to and if your not used to handling a myriad of different trailers then I could see something a little out of the norm being a little sketchy for some.
OEM spec tires? In general, the 20-30 new trucks I've had, the OEM tires are mostly mushy pieces of _____. Nothing says stability and confidence when loaded or towing like a heavier, stiffer, better traction in inclement conditions tire.
One person's definition of scary may be another's definition of easy towing. I think am beginning to figure out what the polar attraction is to weight distributing hitches though. For those that have not towed alot, it must really enhance the sense of security. I need to try one sometime...
Grit dog wrote:
Do the math....got what? 5-600 lb tongue weigh maybe?
Hitch 3' behind rear axle, roughly. Front axle 12' in front of rear axle.
600lbs on the hitch takes 150lbs off the front axle.
Not enough to make much difference at all. 75lbs off each tire...
The math is only part of the story. The reality is in driving. Yes, some trucks will just fine. Others not so much. The part the math can't take into account is the truck's suspension.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
Grit_dog
Navigator
Navigator
APT
Lots of things can be a problem, but I recommend spending a couple hours with that WDH. Tilt the head angle more and fewer links under tension. Spend $15 at a CAT scale sounds like a cheap potential solution compared to many other ideas that are speculation and potentially costly to change.
3 passes with 3 axle weights
Truck alone
Truck with trailer without WD bars
Truck with trailer with WD bars
Truck front axle
Truck rear Axle
TT axles (both)
If your front axle weighs 3200 pounds alone, trailer tongue on ball may give up 300 pounds to 2900 pounds. Adjust that WDH to get back to 3200 pounds.
Grit_dog
Navigator
Navigator
"Actually that's not necessarily true. Just 1/2 inch in increased front fender height can make for a scary ride in a 30 mph cross wind. And 4400# is enough weight on a 150/1500 series truck to need a WDH.
And yes, those AT tires can be a problem. I just replaced my tires with OEM speced tires and it's a world of improvement from the AT tires I had for 3 years. "
BenK
Need much more info and actual weights in order to provide useful opinions, but the final decision is the OP's
What is the TV's :
  • GVWR
  • front GAWR
  • rear GAWR
  • Actual weights of each axle, fully loaded ready to go RV'ing
  • What does your TV instruction manual say about WD'ing...back to original height or weighting in reference to non-WD, etc
What is the Trailer's :
  • GVWR
  • actual weight
  • tongue weight...okay to use the brochure listed, but have to use that in reference to the brochure trailer weight...this will be a percentage of the dry trailer weight. That will provide the ball park tongue weight when fully loaded, ready to go
What is the HD hitch system :
  • type or brand and model
  • Spring bar or truniun bar rating
The OP is going to go around in circles touching, adjusting, etc all of the various dials/knobs without the above info and am wondering if the OP knows the goal in all of these adjustments...to get the TV to what the manual recommends after WD'ing...that the trailer tongue weight should be around 12% of the trailer's actual weight...that the trailer tongue should be level or pointed slightly down...
Campfire_Time
Bevo10 wrote:
Not to sound stupid but payload is weight in the vehicle correct? If that's the case the only thing in the vehicle would be two people at 350lbs total. No cargo.
Payload is how much available CC you have. It's on a yellow sticker in your driver side door jamb. Add the 350# of people, the 75# or so the WDH weighs, and the tongue weight. This all counts toward payload. Usually tongue weight can be rough calculated to be 10%-15% of trailer weight. Let's assume for a moment that the trailer is fully loaded and weighs 4338. At 13% that's a 563# tongue weight. That's 988# to subtract from the payload.
Here's a question, is the 4,338# dry weight or GVWR, in other words how much does it weigh ready to camp?
Grit dog wrote:
How much does it sag the truck when you drop the trailer on? Would have to be VERY tongue heavy trailer at that weight to make much difference in steering.
Chuck D.
Grit_dog
Navigator
Navigator
Is it your lack of experience towing or not knowing what to expect? Yes trucks drive differently with a trailer hooked up. But if your trailer is actually only 4400lbs, I canโ€™t imagine even needing a WDH much less it taking a significant amount of weight off the front of the truck.
2โ€ level and some mud tires isnโ€™t by itself going to affect handling that much.
4400lb trailer AND a bed full of heavy โ€œstuffโ€ is a different situation.
Little more about the setup?
