30 degrees for 3-4 hours...
Mickeyfan0805
It's supposed to drop to 30 degrees for 3-4 hours overnight tomorrow, then well back into the 40's during the day. It seems that getting just below 32, for only a couple of hours, should be a non-issue, and since I don't have a compressor, the concept of adding all that antifreeze for just one night seems like overkill. But, I don't want to make a mistake.
Would you be concerned?
13 REPLIES 13
Caveman_Charlie
I run the water heater, open the faucets, put a electric heater inside the TT, and add some pink antifreeze to the holding tanks. Even if there is some water in them I'm not too worried at those temps and the pink will dilute things enough that it will not cause bursting.
1993 Cobra Sunrise, 20 foot Travel Trailer.
stetwood
If you are really concerned at that temp open ALL the faucets. This will allow any freezing water to expand forcing some water out.
As an example.... When I left for work today ,it was 26 degrees at 7AM.... Went inside the camper and it was still 41 . . . It takes a while for EVERYTHING to hard freeze inside....MOST should be fine
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
bob_b1
I was caught off-guard by the dropping temps too. It may have been fine if I did nothing, but I just set my furnace to 50 degrees for the one or two nights where it will be cold. It shouldn't use too much propane or battery power.
'93 Itasca Suncrusier diesel towing a '05 Honda CR-V.
Bob, Pam(DW), Bridget(DD) and Christine(DD)
See you at most of the Penn State tailgates:)
NanciL
No, not at that temperature for that short period.
But I did mine with pink stuff yesterday since they predicted it to go to 19 here.
jack L
Jack & Nanci
Gonzo42
Using advice I got on this forum, we camped in Yosemite recently where the temp at night got to 29 F. The advice was to run the water heater to prevent freezing up. We had no problems in that regard, and we were covered with snow.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
Mickeyfan0805
Thanks everyone - seems like people view it the same way I do. Just wanted to hear from some more experienced people.
Trackrig
Clicky
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Campfire_Time
I don't worry too much about 30. It got to mid-20s here last night. I checked the trailer this morning and there was slush in the lines. Tonight I'm running the heat at about 40. After that were supposed to be a little warmer at night.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
jfkmk
I've camped in colder weather and had no problem. It probably won't get that cold inside your rig anyway. If concerned, you can open faucets to relieve pressure buildup.
Islandman
No problem, it will have to get down into the low 20's for many hours (6-8) before you need to worry. Your water temp is starting out at probably 50F and it takes a long time for stuff to freeze. If you're concerned, stick an electric heater in the RV set at low temp, open the cabinet doors where there is a waterline and the bathroom door and sleep tight.
dan-nickie
No sweat....
Dan and Nickie
2014 Forest River Berkshire 390RB
sch911
No had the same situation in Michigan today and wasn't concerned...
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
