5th wheel nose high
arcticfoxpuller
After putting the camper in the shop for the winter I went and raised the front landing gear as high as I could. With my short legs I can now walk under the front. Will this hurt the suspension or tires. It's really nose high.
THANKS
10 REPLIES 10
TXiceman
It will throw more weight on the rear axle. I'd just leave it level.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
discovery4us
I also wouldn't worry too much about it. Make sure the tires are chocked good. You could also build some 2x12 or similar runners to drive up on and raise the whole trailer to eliminate some of the angle. stack a few boards and you can easily gain 6 - 8 inches in height.
IdaD
I wouldn't worry about it...
2015 Cummins Ram 4wd CC/SB
Dave_H_M
It's just kinda handy for me as I can walk under the front to get access to another door in the shop.
:h
Old-Bisquit has the answer. I can still manage that at over 7 decades but it does put a strain on my bodily overhang. :W
minnow
MFL wrote:
First off, is there a good reason for doing this?
IMO, it is not the best idea to extend landing gear to the limit. I think you are putting unnecessary stress on your suspension/springs, as well as making the rear tires support most of the weight.
I would not do this, especially long term!
Jerry
C'mon. Really??
arcticfoxpuller
It's inside the shop. No fridge running. Not up against the landing gear stops. It's just kinda handy for me as I can walk under the front to get access to another door in the shop.
Old-Biscuit
Hang a ribbon from king pin so you quit running into it and lower the front back down to level
MFL
Nomad II
Nomad II
Jerry
WTP-GC
Is it nose-high as compared to actual level or ground level?
Duramax + Grand Design 5er + B & W Companion
SBGTF
Second_Chance
As long as you haven't over-extended the landing gear and the trailer is protected from gusty side winds, you should be OK. If the frig is turned on, you may damage it - they need to be level. My question would be: why would you want to do this?
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
