Oct-18-2018 09:01 AM
Oct-14-2019 11:41 AM
95jersey wrote:mhamershock wrote:
Before you go all bonkers try this:
https://www.amazon.com/Husky-32218-Center-Line-Spring/dp/B00W919FL8/ref=sr_1_1?ie=UTF8&qid=1540589689&sr=8-1&keywords=husky+centerline+ts+weight+distribution+hitch
Get the 1200 lb bars. I run this now - the difference from a friction bar setup was MASSIVE. And if it doesn't help at least you will have a decent hitch for your next trailer.
M
Just want to follow up on this old post. I bought the Husky Centerline with the 1200-1500 bars and WOW! Huge difference. Tows like a dream. It is really good. No sway even at 65-70mph. This was a great cheap alternative. It cost me $230 or so and works phenomenal. Thanks for this recommendation!
Oct-14-2019 11:16 AM
M
Oct-29-2018 05:27 AM
Oct-28-2018 12:15 PM
Oct-28-2018 10:07 AM
Oct-28-2018 08:22 AM
M
THis is a nice unit at a great price, LOTS of positive reviews THANK YOU!
Oct-27-2018 06:58 AM
M
Oct-26-2018 02:36 PM
Oct-26-2018 02:05 PM
aftermath wrote:95jersey wrote:
FINALLY some useful information. Over the weekend I took the RV to my dealer to get winterized and asked them to weight the tongue.
drum roll...1280lbs (no bikes, no water, but fully loaded otherwise).
I don't know when I will be able to get to a CAT scale, as I am booked every weekend until late November. So for now, this is all we got.
So I am definitely exceeding the WD hitch rating (1000lb) at minimum.
95, a few observations on your situation. First, you have stated that you would like to downsize the trailer. If that is true then do it and be done with all this nonsense. If you are willing to try to get thing under control without spending tons of cash then you have lots of suggestions. 1. Tires: this will not be a waste of money even if you change trailers so start there. 2. A More Sturdy Hitch: Likewise you can transfer this to your new trailer and probably be better off.
And now a question I have. You found out the TW on your trailer but it wasn't loaded with your toys. 1200 is pretty heavy and I am guessing that this number will go way down when you load the TH. How did it handle when empty? Was is stable or did it sway? The rule of thumb is the heavier the TW the more stable the tow. Before you give up, you might want to load your stuff in the back and then weight the tongue. Just a thought. AS you take weight off the tongue it can get more difficult to tow. The challenge here is to keep the numbers within spec.
Oct-26-2018 01:35 PM
Oct-26-2018 07:42 AM
95jersey wrote:
I went to etrailer and there were no aftermarket hitches over 1200lbs and torklift doesn't make one yet for my truck.
So now at the minimum, I need a new hitch and WD system combined in excess of $4000. I can spend less money getting a new trailer. I prefer something smaller anyway, not only for ease of towing, but being able to fit in tighter places.
Oct-26-2018 07:27 AM
Oct-25-2018 10:03 AM
Oct-25-2018 09:37 AM
