โFeb-20-2018 02:16 PM
โFeb-22-2018 08:09 AM
Atlee wrote:
This is why I have 2 2K Hondas. Together, they will power the AC and micro. If I don't need AC, I only have to run one. And I can handle one 2k genny at a time. However, I could never move the 3k machine alone.Ltrip wrote:
I just went through this decision process. Your priorities may be different than mine.
I considered the 3500W units and 2 2000W units.
At age 68 I was concerned about moving the 3500W unit. Also, there are times when you don;t need to run the air, so the 3500W is overkill for other uses.
I opted for 2 Champion 2000W units. I can carry the 49 lb unit pretty easily and it pairs up to create a 4000W unit, enough to run the AC.
Upon receipt, 1 of them started and ran perfectly. The other is in the shop for a warrantee fix of leaking gas. I have not used them yet on a camping trip. But soon!!!
โFeb-22-2018 01:19 AM
โFeb-21-2018 08:44 AM
โFeb-21-2018 08:37 AM
jamesroadking wrote:
Power measured in Watts is the Question. The Formula is P over I E.
Power Over I Current measured in Amps (30 amps) times E Volts (120 volts)
30 amps X 120 volts = is 3600 watts, to run your RV. Now to run just your A/C by it self (mine is on a 20 amp breaker, so 20 amps times 120 volts equal 2400 watts.
I've ran a 4000 watt non inverter Champion Generator for the last 6 years. It cost me about $250 in 2012. It's run flawlessly, all I've ever had to do is change the electric start battery once and change the oil a couple of times. In stock form the Champion generator runs at 68 decibels, and to further quiet it down I routed the exhaust through a stock HD Electra Glides stock quiet muffler. That did the trick, now I can stand right next to it and have a normal conversation. Total cost about $300 bucks.
โFeb-21-2018 01:51 AM
โFeb-20-2018 07:14 PM
Isaac-1 wrote:
Keep in mind it also depends on where you will be using it, engines loose power at altitude, so if you will plan on using air conditioning at high elevations you need a larger one. My Onan 4,000 will power my air conditioner and microwave oven at the same time with no problem here in Louisiana, but when I tried running them both at 7,000+ ft elevations last August in Wyoming the engine would bog down.
โFeb-20-2018 06:11 PM
โFeb-20-2018 05:25 PM
โFeb-20-2018 03:43 PM
azrving wrote:2oldman wrote:
Oh, no, I'm not suckering for another generator thread. ๐
Come on, just tell us which brand is best. ๐
โFeb-20-2018 03:20 PM
โFeb-20-2018 03:12 PM
โFeb-20-2018 03:11 PM
pianotuna wrote:
Add a soft start system such as the one from Microair Easy Start.
I'd choose the Champion 3400 watt with remote electric start.
โFeb-20-2018 02:44 PM
โFeb-20-2018 02:43 PM
