AC question
JWRoberts
I have recently purchased a new 2016 Dutchmen Denali 325RL. About 2 weeks into an 8 week trip through the mid west, the AC would only cool to about 5 degrees below the outside temperature. And two other odd things occurred that I've not seen before in 30 years of RVing.
The AC fan never cuts off when the AC is on. The compressor seems to cycle on and off, but not the fan.
Also, when the furnace comes on, the AC fan comes on.
I have an appointment with the dealer next Monday but I'm curious if new campers has AC fans that never turn off and come on when the furnace is on. My previous 3 campers did not.
3 REPLIES 3
Halmfamily
Try resetting your thermostat. Look up online on how to do it. Had an issue last year and had to reset ours and no problems since.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
JWRoberts
Should have mentioned that the AC fan is set to Auto with the AC on.
momentum_rv
My AC is dometic and if the fan is set to hi or low instead of auto it will run as you describe including the furnace part.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
