โSep-10-2015 05:54 AM
โSep-11-2015 03:10 PM
n7bsn wrote:
Generally, a higher antenna will out preform a lower antenna.
A bigger antenna will out preform a smaller antenna.
Those little antenna's that mount directly on the roof work very poorly.
โSep-11-2015 06:54 AM
โSep-11-2015 05:29 AM
โSep-11-2015 03:34 AM
โSep-11-2015 03:14 AM
majorgator wrote:All you said was "upgrade" and there are often reasons over just wanting the best. The Batwing outperforms anything else out there but its also more prone to internal breakage due to the long VHF element. There is yet another FCC reshuffle of the TV channels coming now due in March 2016, and when that happens there is a better than excellent chance that the VHF channels will again fill up. Of the three antennas mentioned in this thread, the Batwing is the only one that was built with VHF in mind. I suspect the competition will scramble to catch up in the next few years.SCVJeff wrote:
Neither one are an "upgrade" to a WORKING Batwing either with the Wingman, or the newest Sensar built-in.
Whats the reason for you considering this?
Reasoning is explained in the opening comment...curiosity of whether or not one is better than the other. If there is no benefit, then there is no reason to change.
Thanks for those who gave those real detailed responses above. I didn't expect to get so much good info!
โSep-10-2015 06:55 PM
โSep-10-2015 01:50 PM
โSep-10-2015 12:07 PM
โSep-10-2015 08:36 AM
โSep-10-2015 07:48 AM
majorgator wrote:I don't know what you mean by "Winegard HD Antenna". All Winegard TV antennas are HD including the "Batwing". If your present antenna is in good shape, you might want to try adding the Wingman attachment. Also make sure your coax cable and connectors are in good shape. Many reception problems are caused by loose or corroded connectors or bad coax. Here's a link to an article on tuning up your antenna: Antenna tune-up
For those who have done it, is the King Controls or Winegard HD Antenna worth the upgrade over the stock bat-wing antenna? If so, is it better to get the one that mounts right above the roof or the one that mounts to the mini-tower that raises up and down?
โSep-10-2015 07:10 AM
โSep-10-2015 07:06 AM
โSep-10-2015 06:08 AM
โSep-10-2015 05:59 AM
