Anyone flat tow Toyota Tacoma 4x4
wbrowning
Can you flat tow a Tacoma 4 wheel drive either auto trans or standard trans.
22 REPLIES 22
JohnnyT
Moved from class A forum
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee, Ford F150
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
msmith1199
The 4x4 Toyotas do have a neutral position in the transfer case and I was told by a salesman and his boss that you can tow it four down and in neutral just like the Jeep and Dodge's. I pointed out to them that the owners manual said the vehicle could not be towed four down. They said Toyota just put that in there for liability purposes. So I told them I'd buy the truck under the condition that we have a side contract that states that I intend to tow it four down and that the dealership agreed to take full responsibility in the event of any issues regarding warranty work that may be voided because of my towing it four down. They would not agree to such a contract so I didn't not buy the truck. Got the Dodge Dakota 4x4 instead and it is towable four down and it is approved by Dodge to be towed that way.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
jarviswin
I tow a 2007 dbl cab, V6, auto. I have a drive shaft disconnect with a Unified Tow Brake system. As long as you clean and lubricate the mechanism a couple times a year, it works great.
2006 Allegro 32B
2008 Honda Civic (Toad)
2009 V Star 1300
wbrowning
2004 Crew Cab 4x4 V6 Looking to buy one for work truck I will buy standard if auto will not work.
oldmattb
We flat tow an FJ cruiser auto 4x4, which is similar. I looked into the driveshaft disconnect, but it was over $1000, and of questionable durability for off-roading. For the dozen or so times we have towed it, i just remove the driveshaft. It takes maybe five minutes, two wrenches, no jack. So far. I have paid myself $500 an hour for lying on my back with a wrench!
Matt B
oldMattB
1998 Monaco Windsor
wbrowning
lanerd
What year? 2WD or 4WD? Access Cab, Crew Cab? 4cyl, 8cyl? Need more info!
I don't think ANY Tacoma of later years can be towed 4-down without the drive shaft disconnect. We use to tow our 86 P/U 4x4, 5-speed with no problems.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
gone2dadesert
My friend flat tows a late model 4runner, but he had to use driveshaft disconnects. :R
2011 Hurricane 31J
2008 Jeep JK Unlimited Rubicon
