โApr-19-2016 04:47 PM
โApr-21-2016 02:18 AM
โApr-20-2016 05:33 PM
โApr-20-2016 05:23 PM
โApr-20-2016 03:58 PM
โApr-20-2016 03:32 PM
โApr-20-2016 01:05 PM
Goostoff wrote:I do and I'm glad to say I've never had an issue with not being able to get a lug nut off. Used correctly anti-seize does just what it says. The warnings against using anti-seize is so you don't overtighten that lug nut using dry settings.
My method is to set my clicker torque wrench to 105 ft lb and I should be able to just budge them before it clicks. an extra 5 lbs isnt going to hurt anything. Proper torque isnt necessarily to keep the wheel from falling off. It is to keep idiots from cranking on them until they grind and to ensure that they are tightened evenly to keep from warping rotors and drums.
On a side note but still related, how many of you anti torque stick folks like to use grease and never seize on your lug nuts?
โApr-20-2016 12:24 PM
ensure that they are tightened evenly to keep from warping rotors and drums.Right! The corporation which I worked for on heavy industrial machinery taught us that it was more important to have ever bolt or nut torqued evenly than to have them torqued to down to an exact foot poundage, within reason of course. ๐
โApr-20-2016 10:05 AM
โApr-20-2016 09:55 AM
โApr-20-2016 09:35 AM
โApr-20-2016 09:23 AM
mgirardo wrote:jfkmk wrote:Goostoff wrote:
My most commonly used one is the 19mm 100 ft lb and I usually test it every couple months with a torque wrench to make sure it is still doing its job.
Can you explain how you test the torque of the torque stick with a torque wrench? They need to be used with an impact wrench set to a certain torque range to work right, so unless you're beating your torque wrench to death, I don't see how you're doing this. Yeah, you might see the stick start to twist a little, but that's no indication of how much torque you might be putting on a nut or bolt while using it.
I would expect he uses the torque stick to tighten the nut to the specified torque. Then takes his torque wrench to see if it indeed tightened to that amount of torque.
-Michael
โApr-20-2016 08:06 AM
โApr-20-2016 06:13 AM
hotbyte wrote:mowermech wrote:
If torque sticks are so great, why don't they use them on cylinder head bolts, rod cap bolts, main bearing cap bolts, etc.
Why were we not allowed to use them on aircraft wheel tie bolts? How about aircraft engine mount bolts?
Would YOU be willing to fly on an aircraft that had been assembled using torque sticks on all the bolts?
Sorry, but if you are going to work on my tires and wheels, you WILL use a torque wrench, or I will not be back for any further services from your shop!
Good Lord...Of course the torque sticks don't have the precision for all of those items you list but for a wheel lug nut, they are fine. I bet most lug nuts tightened based on number of "bubba grunts" and have no issues.
โApr-20-2016 05:38 AM
โApr-20-2016 05:34 AM
