Battery Disconnect Lever Question
goreds2
When the Battery Disconnect lever is set to OFF, does this mean the battery is connected?
In so doing, Battery Disconnect lever is select to ON, so this means the battery is disconnected?
See Picture In My Profile
I have a 1989 Dodge XPLORER RV Class B - Purchased 10/15/10 IN CASH
Fiance' purchased a Class C 2002 Dynamax Carri-go on 5/1/15 IN CASH
We've got the best of both worlds
5 REPLIES 5
beemerphile1
Don't know what switch you are using but correctly it should be open and closed.
Closed = power flows thru
Open = the circuit does not allow power to flow
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
MrWizard
Moderator
Moderator
think of it as 'battery Connect' relay
on is power
off is no power/disconnect
I can explain it to you.
1997 F53 Bounder 36s
time2roll
Typically 'OFF' would be an open circuit and the battery is disconnected.
If you are plugged in or the RV is in use you should have the switch on.
enblethen
Off, no power
On, power
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Boon_Docker
A real easy way to find out. Turn on a light in the trailer (when not plugged in to 120 VAC), then switch the disconnect to ON or OFF.
