โDec-10-2017 07:08 AM
โDec-12-2017 12:44 PM
sgfrye wrote:RCMAN46 wrote:
This will not help you now but in the future may be very helpful.
I have a set in my trailer and also use one on my home barbecue.
That way I know if there is enough to do the steaks this evening.
Propane level checker
x2 on these. i have a pair for my 2 tanks. pull out my iphone and check.. 6 months of use i like them. pricey but long term investment
โDec-12-2017 05:10 AM
โDec-11-2017 02:10 PM
Stefonius wrote:That sounds like mine. I'm going to try the Dometic jobby and see how it works.fj12ryder wrote:I feel your pain. I can't for the life of me figure out why the propane compartment door couldn't have been made just one inch taller. The tank literally cannot come out vertically. It has to be rocked back on one edge and pulled out diagonally, with the break in the top ring centered over the top of the compartment door.
Not with my 5th wheel. It's a real pain, almost literally, to get the tanks out to fill, let alone just to weigh.
โDec-11-2017 12:47 PM
โDec-11-2017 12:04 PM
Dutch_12078 wrote:
I use a simple handheld baggage scale to weigh my DOT cylinders. I think it cost about $9...
โDec-11-2017 07:47 AM
โDec-11-2017 05:43 AM
โDec-11-2017 05:15 AM
Dave H M wrote:Grit dog wrote:
My apologies, like others, unless I buy a pre filled tank, I've always paid by the gallon, in many states. Didn't know some parts of the country gouge for propane.
In your case all of the options mentioned will work.
I have very rarely paid by the gallon. The places i frequent most have a sign posted as to what they charge for say 20 or 30 lb. Way it is. So maybe that is why the op is wondering how much is in the tanks. I got the same thing going on. My camper has been in the barn since this spring and since I am older than dirt, don't remember for sure what my tanks status is since I turned them both off when I backed it in the barn. The flat rate is OK with me if that is what is posted clearly. I don't see how that can be gouging if you have a choice.
โDec-11-2017 04:35 AM
fj12ryder wrote:jplante4 wrote:I wonder if those actually work well. I hate the idea of spraying down the inside of my tank storage area with water when I want to find the level of propane. One thing I don't need is rust.
Run the propane (stove or furnace) and spray the tank with water from a mister. The temp difference between the gas and liquid should show up as a dew line.
Alternately, you could get one of these.
Somebody needs to buy one of those and report back on their efficacy. C'mon, somebody step up and take one for the team. ๐
โDec-11-2017 04:18 AM
riven1950 wrote:
Farmboy666, I didn't say I had a problem getting my tank filled. I asked a simple question about determining amount of propane in a tank. You could either answer the question or hit delete and move on.
๐
โDec-11-2017 02:57 AM
โDec-10-2017 08:54 PM
โDec-10-2017 05:51 PM
Farmboy666 wrote:You're reading a lot into this. No problem getting my tank filled and I usually do it when it's empty.fj12ryder wrote:Grit dog wrote:Not everyone works the way you think they should. We have two outfits that fill tanks, one is the local propane supplier, and they both charge a set price. So you pay for a full tank even if it's only 1/2 empty.
Why not just go fill up the partial bottle of you think it's low?
Not sure who charges full price, every propane outfit or gas station I've been to charges you what they dispense.
Or....isn't that why you have 2, so when one runs out?
Exactly how much money are we talking about for a full tank? I guess if I had such a problem getting my tank filled and had to worry about being charged for more than I got I would keep a better handle on what was going on.
