โJun-14-2020 03:01 PM
โAug-04-2020 05:36 PM
Lynnmor wrote:
Since jacking under an axle is something that axle manufacturers donโt want, how much pressure can those X-Chocks generate jacking between the axles?
โAug-04-2020 03:38 PM
Cummins12V98 wrote:fj12ryder wrote:
Nope, those can, and will, pop out. Definitely don't use those to chock your wheels. I certainly wouldn't trust them.
If tires are far apart I agree. If close as in pic above they won't budge.
โAug-04-2020 03:15 PM
โAug-04-2020 01:25 PM
โAug-04-2020 01:11 PM
โAug-04-2020 12:47 PM
JRscooby wrote:
Buy Buy buy. How much wider do the wedges need to be to work. Bolt wood or rubber to the wedges you have.
I put a 4X4 behind the tire, and a 2X4 in front. Measured the distance between, added half inch. Bolted 4X to old rubber mud flap, and the 2X under flap spaced at my dimension. Backing in tire gets on flap, so can't slide, then runs over the 2X4, and stops against 4X4. I leave in the yard, so as soon as I back in she's chocked. Plus no reason to get the weed eater close to tires
โAug-04-2020 11:27 AM
โJul-30-2020 09:40 AM
Forum Rules wrote:
You may not use the Open Roads Forum for "For Sale" or "Wanted" posts. Solicitations by private/public agencies, or individuals for any cause are also not allowed.
โJun-17-2020 05:14 AM
Armand_C wrote:
So today while trying to get our new fifth wheel ready and loading up our gear into the new trailer, I noticed that the gap between the wheels was considerably wider than our old trailer. I took out our rotochocks and verified that indeed they were not wide enough to fit between the wheels. (i guess that's another item that I'm going to give to the new owners of our old trailer). While looking in to purchase a new set of rotochocks, I discovered that I couldn't find them online anywhere. In fact, they don't even appear when entering the name in the search engine. The closest thing i have found, is the BAL wheel stabilizer. Just wondering what the best chock is out there on the market or what most people are using? Sad to see rotochock go away, I really liked them and were easy to use.
โJun-16-2020 08:38 PM
wildtoad wrote:
All youโre trying to do is to keep the unit from moving. A rock, brick, piece of wood, broken branch, plastic chock, rubber chock will do that job. You can pay big bucks for the best but it wonโt work any better than the list above.
โJun-16-2020 01:57 PM
jdc1 wrote:
Those mechanical wheel chocks are a lawsuit waiting to happen. Use a rock or wood chocks.
โJun-15-2020 02:45 PM
โJun-15-2020 02:37 PM
โJun-15-2020 02:19 PM
