Black holding tank won't drain past 2/3
Ritkei
After 4 days of camping we have a full holding tank. I open the black valve and hear a rush of fluids for about 1 min, then nothing. Check the tank level inside and it shows 2/3 full. After searching I found a post that suggested filling all grey tanks and pull all the valves at same time, causing enough of a vacuum to get the holding tank to drain. This worked once and now I'm stuck at 2/3 full again. Never seems to drain below 2/3 full. Any ideas or tips tricks?
34 REPLIES 34
D___M
silvercorvette wrote:
gcloss wrote:
352 wrote:
Sometimes stuff gets stuck down there. Reach your arm down the hole as far as you can. When down to the max feel around for anything chunky. Grab it and squeeze it between your fingers until it gets smaller then dump some water in it (After you pull your arm out of coarse}. Do this once a month for regular maintenance. Wash your hands before cooking. I do have a self help video available. Hope this helps
I'll bet someone will read this and give it a try
I just did:S
Please....Please...don't tell us that. It will be many hours, and it is take many beers for me to get that image out of my head. :B
Dave
Mary, the world's best wife (1951-2009) R.I.P
Lizzy (a Boston)
Izzy, Pepper & BuddyP - Gone but not forgotten
2005 Itasca Suncruiser 35A
My computer beat me at chess once; but it was no match for me at kickboxing.
bob_nestor
I was having similar problems and someone suggested Unique Super Digest-It.
Super Digest-It Safe Drain Opener
Put some in the black tank and filled it up with water, let it set about a week and then dumped it. Everything came out as a liquid.
My black tank sensors appear to be sensitive to the least bit of moisture on them and when I dump I sometimes see the 1/3 or 2/3 indicator. I usually dump at a site about 10 miles from my home, but by the time I get home with "empty" tanks the indicators do read as empty.
Bonefish
This is exactly why I use bacteria and enzyme to break down waist so I don't have to with my hand. :S
352
I just did:S
All clear now?
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
silvercorvette
I just did:S
2014 4 WD Silverado 403 CI diesel long bed dually, B&W hitch with 95 Gallon Auxiliary Fuel Tank, pulling a 33 foot Holiday Rambler Alumascape suite, Winegard SK-3005 TRAV'LER slimline dish, Splendide 2100 XC washer dryer, TST Tire Pressure monitor system.
gotsmart
Ritkei wrote:
After 4 days ... Any ideas or tips tricks?
Yes, connect a second hose to the tank rinser when dumping.
2012 Keystone Alpine EXTERIOR FEATURES:
โ€ข--- MAX TURN high-gloss fiberglass front cap & rear featuring
โ€ข30% better turning radius
โ€ขAerodynamic design w 18% better drag efficiency
โ€ขHitch Assist back up mirror w lights
โ€ขHigh Gloss exterior sidewalls baggage doors and entry door
โ€ขClass A style dual latch slam baggage doors
โ€ขKeyless Entry
โ€ขEasy open 4-step entry steps w recessed rope lighting for visibility
โ€ขSuper-size 64 tall 30 wide entry door
โ€ขMotion activated porch lighting
โ€ขDeluxe Graphics package
โ€ขHigh Gloss fiberglass rear cap
โ€ขReverse (back up) lights
โ€ขOne piece polypropylene underbelly
โ€ขTriple insulated ducted and heated holding tanks
โ€ข---All-IN-One Waterworks exterior utility center featuring
โ€ขEasy siphon winterization system
โ€ขWater heater bypass
โ€ขEnclosed low point drain valves
โ€ขDucted heat for cold weather protection
โ€ขDump valves
โ€ขSoap dispenser
โ€ข110V outlet
โ€ขBlack tank spray hookup
โ€ข16 E-load radial tires w 8 wheel lugs
โ€ขHeavy duty 7000lb axles
โ€ขEasy lube axles
โ€ข12 -Beams with Z-frame technology
โ€ข---Equa Flex Suspension featuring
โ€ขImproved impact absorption
โ€ขImproved axle equalization
โ€ขGreasable wet bolts
โ€ขLong lasting 12 steel shackle plates
โ€ขLong lasting bronze bushings
โ€ขNo Sweat vented attic system
โ€ข50AMP service w detachable power cord
โ€ขHydraulic selector valves for slideouts
โ€ขHydraulic front landing jacks w 8 diameter all-terrain landing pads
โ€ขGutters w rain spouts
โ€ขRear Ladder
โ€ขOne-Touch electric awning package w adjustable arms
โ€ขTinted 80% safety-glass windows
โ€ขElectric rear jacks
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
garyhaupt
Just go look...flashlight...open the valve, with the water pump off, of course. It won't hurt you.
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
Ric_Flair
You have to be looking into the drain pipe with a flashlight while your wife pulls the valve handle before the other 1/3 will come out.
2013 GMC 3500 DRW 4x4 SLT Duramax
2013 Road Warrior 415 Toy Hauler
2013 Kawasaki 4010 Mule
gcloss
2012 Ram 2500 Big Horn Crew Cab 8' box
5.7 Hemi, 4x4, 4.10
2015 Jayco Eagle 284BHBE
el_jefe1
I had the same problem, could see I had an actual blockage. Valve was open, but still a lot of water in the black tank. The solution I used is probably the cheapest and easiest - 5 gallon bucket. Fill it up with water from a faucet or the shower, dump it all down the toilet quickly. The extra pressure from the large volume of water broke up whatever was clogging it up and got it flowing again. Now I do that as part of my regular maintenance of the tank. After dumping, dump a bucket or two down and it keeps everything pretty clean.
2018 Keystone Passport 3290bh
2007 Chevy Express 3500
Me, the Wife, and a whole bunch of kids
doxiemom11
Our black always reads full. The only times it doesn't is right after a backflush. The tanks empty, it's just the level indicators that don't work properly. I understand this is a very common problem.
PS - If your tank is truly getting full, it will start making belching type noises when you flush. Then it's really almost full.
silvercorvette
I have one of THESE CLEANING WANDS, my guess is that if you allow too much time to accumulate between cleanings the cleaning wand will not work. It is more of a prevention device than a device that will clean up muck that has been allowed to accumulate and harden.
Old-Biscuit
Everybody has commented on the sensors.........but your one statement (highlighted) makes me think you have a blockage occurring when dumping.
This could be the result of the one of the cut-out disc (installer cuts a hole in tank for drain line in/vent line/drain line out) was left in tank. It will float around and then when draining it gets sucked down to drain outlet and blocks tank drain.
This is IF the tank is 'really' only partially draining.
Cut-out discs left behind are a pain in rear-end to remove.
Drain valve needs to be removed and then disc grabbed hold of and pulled out.
352
