โJun-12-2017 07:39 PM
โJun-13-2017 01:37 PM
drsteve wrote:
I would inspect the hot wire for any breaks or cracked insulation. It works OK once the fuse is replaced, I assume? Sounds like the motion of towing might be causing a short.
โJun-13-2017 11:26 AM
โJun-13-2017 07:42 AM
โJun-13-2017 07:18 AM
drsteve wrote:acritzer wrote:
2 times now on our recent trip I've tried to unhitch and found my fuse blown. Any ideas why this happens? I set up, plug in and start to unhitch. That's it.
I assume it's OK when you hook up. Is the fuse blown when you arrive at the campsite? Does it blow when you plug in to shore power, or when you hit the switch to raise the tongue jack?
โJun-13-2017 06:12 AM
โJun-13-2017 05:32 AM
โJun-13-2017 04:46 AM
